20 Most Recent Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Questions & Answers
How to reset when red light is on?
http://www.shopjimmy.com/mitsubishi-930b929001-power-supply-unit.htm replace this part
8/25/2015 10:31:39 PM • Mitsubishi... • Answered on Aug 25, 2015
When installing new lamp, should ballast be replcaed also?
Is there any noise coming from the cable box? My TV had similar problems, and when I had Comcast change the faulty box, the problem stoped
7/2/2014 10:36:22 PM • Mitsubishi... • Answered on Jul 02, 2014
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
5/10/2014 1:12:35 AM • Mitsubishi... • Answered on May 10, 2014
Is it possible for me to switch out the SMPS power supply myself?
Can't see any reason why not, as long as it has the same specifications!
4/23/2014 5:30:23 PM • Mitsubishi... • Answered on Apr 23, 2014
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
4/23/2014 5:10:56 PM • Mitsubishi... • Answered on Apr 23, 2014
Started with watching a movie
Which light is flashing red? Reply to this same post and I will assist you with the problem.
3/13/2014 12:11:25 PM • Mitsubishi... • Answered on Mar 13, 2014
Red light stays on sound no picture
YOU TV LAMP IS GONE. REPLACE IT.I can help you if you send me a line at [email protected] or call me with a message at 8473806394 with your phone number.
11/2/2013 6:19:08 AM • Mitsubishi... • Answered on Nov 02, 2013
New Mitsubishi tv lamp isn't plugging in to make
you have to make sure you get the plug on the lamp fitting sits right so it will go home to the other end. make sure its not broken or moved as it will not locate on to the other end when fitting.
10/5/2013 1:20:49 AM • Mitsubishi... • Answered on Oct 05, 2013
0answers
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on
If you have a voltage meter there are some things you can check.Unplug the unit and remove the back cover of the set. Then Plug the unit back in.You will need to tape down the lamp safety switch in order to do these tests.Here are all the failures that would give you a lamp error and what to check.Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.This is all I have and I wish you luck.
3/20/2013 4:24:14 PM • Mitsubishi... • Answered on Mar 20, 2013
Status Light flashing yellow after replacing the bulb
your air filter cover is loose or not on.
1/26/2013 4:26:30 AM • Mitsubishi... • Answered on Jan 26, 2013
I have white and sometimes red lines and they move and I recently replaced the bulb
Look to see if same issue with the audio and video inputs on rear, usually a problem with lines will not come and go but, it may be possible.Also it is possible if you snap a good photo to post it here to be seen.
12/10/2012 2:19:05 PM • Mitsubishi... • Answered on Dec 10, 2012
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
140 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
install
  • Televison & Video
