20 Most Recent
Ricoh Aficio 1018D Copier Questions & Answers
SC922 Error
922 B IMB DRAM error
The machine detects a discrepancy in
the IMB DRAM write/read data during
its write/read test (done at power off/on
and at recovery from low power or
night/off mode).
• IMB defective
• BiCU defective
• Poor connection between BiCU an IMB
might be time to replace copier for what it cost to fix it.
Resetting sc542 error
Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Fusing thermofuse open
• Power supply board defective
and for reset use prog 5-810 as follow
Resets all level-A service call conditions, such as fusing
errors. (To reset SC 547, switch the machine off/on.)
[0 = No / 1 = Yes]
• After selecting "1", press the Original Type key and the
' key (or OK key) at the same time to execute the
reset. If the reset is successful, the display shows
"Action completed." If the reset fails, the display shows
"Error!!!".
Sc 925
CHECK THE THE HARD DISK
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point.
Aloha,
Bill Monroe
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER?
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
