20 Most Recent Mitsubishi WS-65615 65" TV Questions & Answers
0answers
I have a Mitsubishi WS-65615 projection tv that will only work with being hooked up to Antenna 1 main input. Anytime you access the device menu from either the remote or front panel the picture gets a
It sounds like you have a short circuit close to your switch somewhere. It also might be a bad capacitor (small one) in the auxilary circuit.. when it is activated it drives eithe video or audio driver to max causing your TV watchdog circuit to clamp. I can not see your pictures very clearly, but look at all the electrolytic capacitors (round "can" looking parts) to see if any are "bulging" on the ends on them (this means they are shorted out inside from drying out or physical damaged). Also look to see if any parts are shorting out inside. The pictures that I can see look like your TV is pretty clean, so I suppose that you have cleaned it with air or a smal brush. My money would be on either bad caps or shorted out component by touching another one.. check it out!
1/10/2015 2:11:53 AM • Mitsubishi... • Answered on Jan 10, 2015
My rca 27" flatscreen crt tv model # tr29m62 power light just blinks but it does not come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Gopakumar Gopalan Google
2/13/2014 10:14:06 AM • Mitsubishi... • Answered on Feb 13, 2014
Update firmware
If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Firmware update procedure to many brand TVs are given in details with screen-shots.
11/11/2013 9:08:11 AM • Mitsubishi... • Answered on Nov 11, 2013
Wont power on
Check and replace its main power regulator board.
7/29/2013 2:44:57 PM • Mitsubishi... • Answered on Jul 29, 2013
manual
Losing sound intermittently
Its muting circuit section should be troubleshooted. This is a skilled work. Contact any experienced service technician
9/19/2012 12:01:41 PM • Mitsubishi... • Answered on Sep 19, 2012
Hd tv mitsubishi
is the led flashing? if the led isnt flashing but is lit then press the power and menu buttons in together on the front of the set and hold them both in together and see if it flashes a two digit blink code. then let me know what happens. If it blinks constantly let me know that as well
6/12/2012 12:45:00 PM • Mitsubishi... • Answered on Jun 12, 2012
2answers
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
2/28/2012 1:41:41 AM • Mitsubishi... • Answered on Feb 28, 2012
MY TV IS NOT COMEING ON IT IS MITSUBISHI
This is NOT a solution but a suggestion:
So you may know what is wrong, if power light (green) comes on and then goes off:
PRESS AND HOLD"device" and "menu" buttons on front of tv for at least 5 seconds and thenrelease both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
6/26/2011 2:29:49 AM • Mitsubishi... • Answered on Jun 26, 2011
5answers
I have a Mitsu Medallion
What is the Model number Printed on Back of TV?
Thank You.
6/14/2011 8:37:17 PM • Mitsubishi... • Answered on Jun 14, 2011
2answers
Telivision dont want to power up.
You are experiencing the Mitsubishi Green Blinking Light of Death which is fixable.
All you need to do is replace the four 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors) which are inadequate for this tv. These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. It is then recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur.
If you are good with soldering and know how to work with electronics then this will be an easy fix otherwise I suggest getting someone to replace the capacitors that knows how to deal with them without getting an electrical shock. You can get the capacitors at any electronics store such as Radio Shack.
Good luck and please let me know if you have any further questions.
thanks
9/23/2010 11:26:03 AM • Mitsubishi... • Answered on Sep 23, 2010
How do i take the parental code off of my
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
4/30/2010 7:32:21 PM • Mitsubishi... • Answered on Apr 30, 2010
3answers
The reason there is no picture is (95%, certainty) the loss of the high voltage. The high voltage is what produces the energy for the raster lines upon which the video is modulated.
Therefore, the video and deflection circuits may be working just fine but you cannot see because there is no high voltage to the picture tube.
Now, it is possible, also that power to the picture tube filaments has been lost, or that the power supply to the biasing voltages is defective or that the picture tube sockets are corroded, but the overwhelming cause among TV sets is loss of high voltage.
Refurbishing the high voltage will probably cost $250 or from anywhere you go. Even if you do it yourself and buy the parts wholesale you will not save a tremendous amount. So, unless you are very handy and know how to troubleshoot, solder, repair and test, I think you are better off finding a good shop for the repair.
3/24/2010 1:09:42 AM • Mitsubishi... • Answered on Mar 24, 2010
2answers
How do i set video from 480i to 1080i??
when your using the comp in or hdmi the tv should swithch automaticlly but you must have an HD signal
11/30/2009 7:51:29 PM • Mitsubishi... • Answered on Nov 30, 2009
The TV only shows a royal blue screen. I can get
This would appear there is no incoming signal. Check your antenna or cable connection is connected securely & then try to retune the TV once more, you should pick up a picture. If not, if you have a DVD connected via a scart, check if you receive the DVD picture. If this is the case then there will be a problem within the tuner stage, possibly a replacement tuner will be required
11/29/2009 9:55:20 PM • Mitsubishi... • Answered on Nov 29, 2009
Power light flashes.
The dm board is located inside the vertical metal case on the left side when viewing the tv2.gif from the back side.
Have you tried disconnecting the front panel on the tv? There are 2 plugs that go into the board and sometimes there is a faulty switch on there which causes your problem.
11/8/2009 8:45:38 AM • Mitsubishi... • Answered on Nov 08, 2009
I tried the solution SD Tech offered about ht
Try the 2nd solution SD Tech gave you...
"If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit."
If you know how to solder I would totally suggest that you repair the set yourself. Don't get in over your head, but you will save yourself a ton of money and gain somewhat of an understanding of how tvs operate.
The green light blinks while the DM board initializes the tv. If the DM board can't initialize it keeps blinking and this is usually caused by blown/bulging capacitors on the Dm board.
11/8/2009 8:34:00 AM • Mitsubishi... • Answered on Nov 08, 2009
I have a Mitsubishi WS 65611 tv. It started
have you checked your auto shutdown timer?
11/7/2009 10:53:21 PM • Mitsubishi... • Answered on Nov 07, 2009
Mitsubishi WS-65615 65" TV Logo
44 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi ws 65615 projection tv will
  • Televison & Video
