20 Most Recent
Ricoh Aficio 120 Copier Questions & Answers
Code erreure sc 300 aficio mp 6000
SC 300
Charge corona error - charge corona power pack defective
SC 300
Charge corona error - charge corona receptical defective
SC 300
Charge corona error - charge corona unit defective
SC 300
Charge corona error - replace corona unit and enblock as set
SC 300
Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Change drum
Californiaia cilindro y cuchilla y pon tinta en el cilindro antes de colocarlo para q lubrique con la cuchilla y no se pegue
Error code on display. Sc402. what does the error
Transfer problem
Your Transfer unit disconnected or bad connection.
Unlikely, but a transfer power supply could be faulty.
A piece of paper stuck in the transfer area could also cause that code to come up.
If the machine is dirty and you see toner all over when you open the right side of the copier, have it cleaned thoroughly, that will most likely solve your problem.
How to reset pcu correctly
Cant remember if these models use the rebuildable pcus or not.
If it does:
change the developer / blade / charge roller/brush and drum if needed then run the TD initilization .
If copy quality is good then you can run td ini without changing those parts and just replace them at failure.
If it doent:
Change the whole pcu
it will reset itself
or if copy quality is good run the td ini and the message will clear.
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
