20 Most Recent
Mitsubishi M-VR900 Receiver Questions & Answers
Mitsubishi M-VR900 remote
Harmony by Logitech; they have models ranging from 70-400 based on your needs. They are 100% programmable, meaning any function your unit has, it will duplicate. PC software is very user friendly. You can set this remote to control up to 14 different devices and one button control. They even pass the Wife/Mother, & in-Law tests.. They have a substantial Database of products on file so you don't have to have your original remote. If you have problems while programming, they will actually answer their phones 14 hours a day. Why do I like these so much? Price/Performance/User friendly & I program all remotes from Universal to Crestron. Hope this helps. If you have any questions, reply & I will answer for you & help any way I can.
I want to know the power output, the watts
It has 100 wats/channel into 6 ohms theoretically.But it doubt it will drive the speakers simultaneusly at the rated power just like most of the receivers-not enough power in the power circuitry/transformer and cause distortion.I think it can handle 30-40 wats/ch without distortion.
No power to my Mitsubishi M-VR 900
try to change the power fuse they look like a clear tube with metalic cap on each side and it is a wire inside them you need to look after a fuse with broken wire and replace it if all fuse are intact i dont know what to do
Mitsubishi pajaro 2006 radio is not working is that fuse causes it?
A non-functioning radio in a Mitsubishi Pajero 2006 could indeed be caused by a blown fuse. I recommend checking the fuse box for the radio and inspecting the radio fuse. If it's blown, replacing it may resolve the issue. However, if the fuse replacement doesn't fix the problem, there could be other underlying issues with the radio or its wiring that may require further diagnosis and repair by a professional
