20 Most Recent Mitsubishi M-VR800 Questions & Answers
2answers
I have a Mitsubishi M-VR800
3/25/2013 10:47:06 AM • Mitsubishi... • Answered on Mar 25, 2013
My rear speakers are not
If you are adamant your M-VR800's menu has been setup correctly (i.e. 5.1 setup test tone confirms all outputs are working), then another possibility will be your disc audio setup.
When you inserted your movie disc, did you check your audio options on the 'disc menu' and select 5.1 from the disc menu?
Some disc menus offer an audio choice between Dolby 2.0 (stereo only), Dolby 5.1 or even DTS 5.1. In this case, you may need to manually choose your preferred audio option from the disc.
9/4/2011 10:05:25 PM • Mitsubishi... • Answered on Sep 04, 2011
0answers
0answers
Seems to be stuck on
Mine is having a similar problem. After it has lost power or been unplugged it will always revert to decoder 4. It seems to need to warm up because after waiting about 10 minutes it finally stays where I tell it to.
12/18/2010 5:31:41 AM • Mitsubishi... • Answered on Dec 18, 2010
Decoder is on and I
Ok, the power outage was not so much the problem, it was when it came back on,and the unit was on and plugged in, that the problem has arisen, you see when the power is reconnected, like this, the "Inrush" current can, and does damage the Power supply, and this is exactly what has happened here. This is a very common occurrence. You see after a Power Outage you should disconnect ALL appliances and withdraw plugs from the wall if possible. Reconnect after the power comes back on. You will need to get the unit looked at by a professional, the power supply is a relatively easy repair,as long as the Spike, surge hasn't "Gone too deep" Please ask for a "Quote" before allowing any work to commence,this way at least you can decide to repair or replace.
4/1/2010 11:43:54 PM • Mitsubishi... • Answered on Apr 01, 2010
Analog RCA output jacks have no signal
First, get into the setup menu and go into audio and make sure it's not locked on Digital or PCM. If it is, there should be a setting for "auto". If you still have an issue, post a comment and I can walk you thru troubleshooting. Hope this helps
6/26/2009 3:15:21 AM • Mitsubishi... • Answered on Jun 26, 2009
2answers
Mitsubishi Surround Sound M-VR800
mine does the same thing.. so far I have no clue other than it may be detecting input from devices like vcr..dvd etc..
11/26/2008 12:43:24 AM • Mitsubishi... • Answered on Nov 26, 2008
Mitsubishi pajaro 2006 radio is not working is that fuse causes it?
A non-functioning radio in a Mitsubishi Pajero 2006 could indeed be caused by a blown fuse. I recommend checking the fuse box for the radio and inspecting the radio fuse. If it's blown, replacing it may resolve the issue. However, if the fuse replacement doesn't fix the problem, there could be other underlying issues with the radio or its wiring that may require further diagnosis and repair by a professional
10/1/2023 12:32:35 PM • Mitsubishi Audio... • Answered on Oct 01, 2023
Owner manual for a mitsubishi equalizer da-g157
See if available on their web site or try a google search.
9/5/2017 2:08:33 PM • Mitsubishi Audio... • Answered on Sep 05, 2017
I have a repaired misubishi stereo tuner model #m-pf5200 i need connecting diagrams for all internal componets
Mitsubishi doesn't publish those diagrams to the public.
12/4/2016 12:15:51 AM • Mitsubishi Audio... • Answered on Dec 04, 2016
I can't use the A/V ext on my Mitsubishi "HOME THEATER MODE" And it'll only go between A- Ant and B- Ant I don't have the original remote for it just a Cox universal remote. Can someone please help???
You should be able to use a universal remote. It will search the frequency for you. TYVM Please leave feedback
7/10/2016 6:28:29 PM • Mitsubishi Audio... • Answered on Jul 10, 2016
Mitsubishi subwoofer m-s8040 fuse blow out as soon as u turn on.
Since this is a powered subwoofer, the problem is most likely in the electronics. The most likely component in the amp would the output device. You could look inside to see if it actually has any discreet components in the output. It may just be a single integrated circuit. If so, many of these i.c.'s are dirt cheap, and can be purchased from many electronics parts outlets. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/14/2016 10:28:01 PM • Mitsubishi Audio... • Answered on May 14, 2016
4answers
I have a mitsubishi DA-R45P home stereo receiver and the unit is useless without a remote does any one know where to buy one.
I suggest go to the store that sells that unit and see what they have to say.
1/15/2016 2:09:44 AM • Mitsubishi Audio... • Answered on Jan 15, 2016
How do I connect my Mitsubishi speaker system M-S8040 sub to my home theater receiver ?
i only see L/R connections sooo choose one only
5/10/2015 4:24:44 AM • Mitsubishi Audio... • Answered on May 10, 2015
0answers
0answers
8 questions posted
Top Mitsubishi Audio Players & Recorders Experts
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Audio Players & Recorders
Most Popular Question
seems stuck
  • Audio Players & Recorders
