20 Most Recent
Samsung SF-4500 Plain Paper Thermal Fax Questions & Answers
How to clear One Touch stored number On SF 1600
To delete all of the number or
name, press left arrow when flashing line is at
the first digit.
To correct a digit, use the right arrow or left arrow to
move the flashing line under the digit,
then enter the correct digit.
If this doesnt work for you You will have to clear the memory of this machine and start over.
Press MENU.
Press 7.
The LCD shows "MEMORY"
CLEAR". 7 . M E M O R Y C L E A R
Press START/COPY.
Select the desired menu by
using or .
The LCD briefly shows the
menu you have selected. T X / R X J O U R N AL
4 Menus available :
TERMINAL ID
SYSTEM DATA
ONE-TOUCH DIAL
SPEED DIAL
TX/RX JOURNAL
5
Press START/COPY.
The LCD asks if you are
If you do not want to clear the
sure you want to clear the
memory, select ‘N’ and press
A R E Y O U S U R E ? Y/N START/COPY.
memory.
6
If you want to clear the
memory, press
START/COPY.
The LCD shows the
message “MEMORY
CLEARING.”
M E M O R Y C L E A R I N G
PRO FAX SAMSAUNG SF 2800
jai un fax/tel samsung sf2800 je n'arrive pas a le regle en de tel façon qu'il sonne 3 fois puis il se converti automatiquement en fax,car c'est ecris en allemand.
salutation amicale.
Samsung Fax/phone model 1600
You could try opening the feeder and clean the gray rollers with mentholated spirits and see how that helps as it just maybe the rollers are slipping slightly.
Once you have done the above take out all of the paper from the back feed and using one sheet blot the leading edge with some spirit and place back into the machine (The back of it) then try coping something there will be a paper jam and do this a couple of times. Once you have done this wipe the area dry put new paper in and then try doing a copy and the paper should feed perfectly now and the test will come when fax comes in.
I do hope this helps you
Thanks J
Printing
REPLENISH PAPER OR INK ,THE MACHINE WILL NORMALL;Y PRINT ALL RECEIVED MEASSAGES
HAPPY FAXING
OMNIPRESENT
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
