20 Most Recent Samsung SF-5100 Plain Paper Laser Fax Questions & Answers
take the power out and hold the red button in. put the power back
Samsung SF-5100... | Answered on Dec 09, 2016
Sorry Samsung doesn't publish this to the internet for public access.
Dear
Go to tech mode MENU-#-1934 press the keys in sequence within 3 sec. to enter in to tech mode and scroll to clear all memory.
Thanks.
Samsung SF-5100... | Answered on Feb 26, 2015
if your fax model is not sf-5100p it can't be used on a pc. the p is for printing
Samsung SF-5100... | Answered on May 29, 2014
hold the red button in and swich unit on or put power in. it will reset but this models where the best but. if the rest do not help. it is time for a new one.
replace toner
Samsung SF-5100... | Answered on Dec 07, 2013
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
the fax is going but not coming i check the system setup please any boldy he know about system please tell me in detail how select and which is select
Samsung SF-5100... | Answered on Nov 21, 2013
CR Fuse Error Samsung 4016. Replacement toner cartridge threw this error, found small glass cartridge fuse on top-front edge of cartridge, swapped fuses with my old cartridge, voila. Replacement fuse was good, had continuity, but felt to me to be slightly smaller diameter than original fuse.
Samsung SF-5100... | Answered on Jun 07, 2012
Most printers/faxes need more than one or two sheets of paper in the hopper in order for printing to commence. If it's not that, take out all paper. Turn off the printer/fax. Wait five minutes and turn printer/fax back on. With some printers/faxes, that almost acts like a re-boot. Good luck!
Samsung SF-5100... | Answered on Mar 28, 2012
you can try to take out the power hold the red button in and put the power back. if it still do not work. it is the mainboard. or liu
Samsung SF-5100... | Answered on Jan 26, 2012
This is a error whit our fuser unit. this the part in front of your fax which is hot. check the bulp inside. if it is ok. check the thermister
you must check the fuser unit. sumtimes it is the bulp or the thermister.
Take the power out and hold the red stop button in and put power back
Samsung SF-5100 Plain Paper Laser Fax Logo
174 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
samsung sf 5100 fax toner empty
  • Office Equipment & Supplies
