20 Most Recent
Norcent Technologies TV2001 20 in. LCD Television Questions & Answers
Channel 2 (cbs) is fine. There is no sound. All
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
11/25/2010 1:59:14 PM •
Norcent...
Answered
on Nov 25, 2010
No screen display
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
8/2/2017 8:22:39 AM •
Norcent...
Answered
on Aug 02, 2017
My power button comes on but the tv dont have a picture or sound
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/3/2014 3:28:56 AM •
Norcent...
Answered
on Nov 03, 2014
Monitor notification of brightness voluntarily
If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/28/2013 6:28:48 PM •
Norcent...
Answered
on Oct 28, 2013
Unlock v chip television
There are many places online to purchase a norcent remote. However, you will need the model number of the remote and the tv to get the exact match. If you would like to provide the model number of both, I can certainly look into it for you
9/3/2013 5:26:35 PM •
Norcent...
Answered
on Sep 03, 2013
