20 Most Recent
Norcent Technologies PT420 42 in. HDTV Plasma Television Questions & Answers
PT4231 have picture no sound, Selection is on internal speakers.
you can go to your menu and select the test tone just to see if your speakers are operational, if not replace the speaker. If you have test tone, then check your input connections. If everything is connected correctly then you need to replace your main board and that should resolve the problem.
6/22/2009 10:53:43 PM •
Norcent...
Answered
on Jun 22, 2009
No screen display
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
8/2/2017 8:22:39 AM •
Norcent...
Answered
on Aug 02, 2017
My power button comes on but the tv dont have a picture or sound
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/3/2014 3:28:56 AM •
Norcent...
Answered
on Nov 03, 2014
Monitor notification of brightness voluntarily
If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/28/2013 6:28:48 PM •
Norcent...
Answered
on Oct 28, 2013
Unlock v chip television
There are many places online to purchase a norcent remote. However, you will need the model number of the remote and the tv to get the exact match. If you would like to provide the model number of both, I can certainly look into it for you
9/3/2013 5:26:35 PM •
Norcent...
Answered
on Sep 03, 2013
