20 Most Recent
Planar PX2710MW Monitor Questions & Answers
Lock out my monitor px2710mw
Here is the user's guide for your monitor:
(from Planar's website)
http://www.planar.com/media/222919/mn-planar-px2710mw.pdf
Planar PX2710MW frequency out-of-range
After a computer reboot, about 8 out of 10 times the monitor would display a blue "frequency out of range" message. It would take several power off/on cycles for the monitor to finally display Microsoft Windows.
I called Planar tech support. They were super-nice. After about 15 minutes in which I shared my screen with them, the tech suggested I go into thePX2710MW's main menu (i.e. "Button 1") and then click "memory recall".
Problem solved! Wow.
Disassemble
the curcuit board would have a little corrosion use methalated spirits and an old tooth brush to clean it off
Recommended resolution is 1920x1080 but
In case you can't show the 1920X1080 option (or higher resolutions) either the VGA controller can not handle these resolutions (so they are hidden) or the drivers for your VGA controller are missing. Clarify me your desktop brand/model to come back with more details.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
I've got a Planar PL2010M monitor that is brain-dead-
1. Try a different DVI cable. 2. Check the monitor's settings and make sure it is set to the correct resolution. 3. Try a different computer or laptop to see if the issue is with the computer or the monitor. 4. Try a different DVI port on the computer. 5. Try a different monitor. 6. Check the video card settings and make sure it is set to the correct resolution. 7. Try a different video card
