20 Most Recent
Honeywell 3800g Barcode Scanner PN 3800G14SERKIT3E Handheld Barcode Scanner Questions & Answers
My 3800g barcode scanner puts
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to
Click hear
My Honeywell plug-in doorbell won't stop ringing
If your Honeywell plug-in doorbell won't stop ringing, there are a few things you can try to troubleshoot the issue:
1. Check the batteries: If your doorbell has batteries, make sure they are properly installed and have enough power. Replace them with new ones if needed.
2. Check the ring options: Press the ring option button with the music sign and cycle through the different ring options until you find one that stops the ringing.
3. Reset the doorbell: To reset the doorbell, unplug it from the wall outlet and wait for a few minutes before plugging it back in. This will allow the doorbell to reset and may solve the issue.
4. Check the chime settings: If your doorbell has multiple chime options, make sure the one that's causing the issue is not selected. You can cycle through the chime options using the settings button.
5. Contact customer support: If none of the above steps work, contact Honeywell customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the doorbell is defective.
2/22/2023 10:53:48 AM •
Honeywell...
Answered
on Feb 22, 2023
