20 Most Recent Polaroid CZA10011B PoGo Instant Thermal Printer Questions & Answers
I've had that problem and running the special blue sheet that comes with the paper pack through the printer seems to work. I've had to run the blue sheet through before each printout for a while, but the problem seems to have gone away - I guess it finally got cleaned out. It also seemed like running the blue sheet through after not using the printer for several weeks was a good idea before printing. When I get a new pack of paper, I run the blue sheet through as instructed. Instead of throwing the sheet away, I store it on top of the blank sheets inside the printer. That way I can use it again if needed.
Polaroid... | Answered on Jan 16, 2013
You can use an universal AC adaptor. http://www.portableparts.nl/?gclid=CN6y34eT5akCFc6JDgod0jeUXQ (for the netherlands, but I assume you can get them anywhere. Just look at the specifications of your adaptor and find a match, or contact the reseller of adaptors..)
Polaroid... | Answered on Jul 03, 2011
Check your camera manual and it should have a code listed for a bluetooth password (or check the printer which might have it's own password). If that does not work then the bluetooth version might be incompatible with your camera/printer.
Polaroid... | Answered on Mar 14, 2011
There is a post about using the free Pogo app in the Android store that solves some problems.
http://www.fixya.com/support/t7303474-successfully_paired_pogo_samsung
The image should be in a .jpg format.
Polaroid... | Answered on Jan 10, 2011
Try putting the blue "smartsheet" registration/barcode paper through each time you turn it on.
How about you check your bank or card statement, or e-mail if the receipt was sent by e-mail.
Polaroid POGO... | Answered on Jan 29, 2015
How was it before ? You can always cancel the old and start A new account.
Polaroid POGO... | Answered on Jan 18, 2015
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
Polaroid POGO... | Answered on Sep 08, 2014
Sign in to what/where? You obviously managed to sign in to FixYa.
Polaroid POGO... | Answered on Oct 14, 2013
make sure you have the software that you need to play them such as direct x is a software you will need to play tons of games on your computer that you installed from a cd.
Polaroid POGO... | Answered on Oct 06, 2013
Remove all Java and Flash from your computer. Once removed, do a Shut down, wait a couple of minutes, power the computer back on, go to Adobe and download and install Flash, after that's done, go to www.java.com and download and install the latest version of Java. Restart the computer, then try Pogo again. Don't skip any of the steps or it probably won't work.
Don't name files with characters like - . & or something like that.Hope that the tip will be useful.
Polaroid POGO... | Answered on Sep 16, 2012
Polaroid CZA10011B PoGo Instant Thermal Printer Logo
13 questions posted
Top Polaroid Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
POGO Polaroid
  • POGO Polaroid
Most Popular Question
keep trying connect tha bluetooth but
  • Office Equipment & Supplies
