20 Most Recent
Dell Inspiron 1750 Laptop Questions & Answers
How do i reset the bios password
Best way is to remove the battery and move the BIOS jumper to the shorting position. Replace the BIOS jumper to the original position and the battery and reboot.
You should now have access to the BIOS.
Authenticate windows vista
The authentication number or password key code is usually available on the computer case. Look for the tag that tells you what operating system is on the computer and there you will find the key codes.
Reset inspiron 1750 back to factory
try "SYSTEM RESTORE' on your computor it will restore it back to a date specifyed by you.go to the START button and click on CONTROL PANEL then go to SYSTEM RESTORE
1 of my letter keys dot work
Dell had known issues with KB issues in the past, it can sometimes be fixed by tightening or losening the screws that hold the keyboard in place, (under side of the laptop, marked KB). hope thisd helps
Webcam isnt recognized wtih drivers installed
Which driver did you install? Is it the one from the website of dell? Please provide more information... If you were trying to update the driver then I suggest that you use RadarSync next time so that you can get the correct driver.
Webcam wont recognize after drivers are installed
Hello,Is it an update or new installation? If it was detected or recognized before the installation, I suggest that you a system restore. If you want to make sure that the driver is correct next time, you can use RadarSync.David
Stuck windows startup screen
Please turn off the computer, start hitting F8 at the startup and then choose last known good configuration. If this does not work, choose Safe mode options. If nothing works, please restore it to factory settings by holding down CTRL key and hitting F11 key up and down at the startup.
