You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command. bootrec.exe /fixmbr bootrec.exe /fixboot bootrec.exe /rebuildbcd Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs. In windows xp you get to the dos command prompt by selecting R for repair when the options appear. In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
29 questions posted
11 Questions
10 Questions
8 Questions
5 Questions
4 Questions
