20 Most Recent Ultra Products Ultra ULT40278 XT MicroATX Tower Computer Case MicroATX USB 90mm Fan 120mm Fan AllInOne Card ATX AllInOne Case Questions & Answers
How do I find a
Motherboard fan connectors typically use a small 3-pin which looks like this: zero_awake.jpg
the left connector is a female connection (the side with 3 holes) the middle and right are male connections, has 3 metal pins:
  • Black: GND (ground)
  • Red: +12VDC or +5VDC (12V or 5V DC - direct current)
  • Yellow: Tachometer signal (used to read fan speeds)
NOTE: Wire color may vary, and some fans or motherboards may control fan-speed.
Some fans use a 4-pin connection, which is generally a CPU fan connector but not always:
This pictures a 4-pin connection, but may look different from other 4-pin connections because the wires are covered in a black sleeve, which keeps them safe from harm and to reduce potential negative affects on airflow created when there are lots of loose wires inside a computer case.
This photo shows a 4-pin connection attached to a motherboard next to a 3-pin connection in a motherboard. While it is not recommended in the case of the CPU's fan, in the case of other internal case fans with a 4-pin connection, it is possible to plug them into a 3-pin connector of the motherboard, but the ability to control fan speed, which is controlled in the 4th pin will be lost.
Though sometimes computers have a way of controlling fan speed on a 3-pin or 4-pin connection even without the 4th pin, such *** voltage regulation and reading tach. feedback. These things are typically things a general user doesn't need to worry about unless their computer is running particularly hot and causing trouble.
In which case, it might be worth investing some money in a fan controller, which takes a power connection, several fan connections (varies based on the controller you get) and gives you the ability to control fan speed externally on your computer case. My controller has nice dial knobs, though some "fancy" controllers have a display and up and down buttons. (Fan controllers would be at your own discretion in terms of price, you can get them cheap all the way up to seemingly ridiculous expensive)
In the event of not having enough 3pin or 4pin connections on a motherboard, it is still possible to add case fans by way of 4pin molex connections:
A female molex connection
A male molex connection
Some case fans run exclusively through these connectors, others have a combination of a 3pin (or 4pin possibly, though I've never seen this combination) and a 4pin molex connector. In this case, the molex connector can connect directly to a cord from the power supply and run the fan. It is possible to run case fans without having them connect to the motherboard at all! Which makes it possible to connect more fans, with less available connections for your fans on your motherboard.
If a fan is a certain connection (any of the 3) and you need to convert it, for example:
  • a 3pin to a 4pin molex because your motherboard doesn't have enough 3pin connectors for all your fans,
adapters are available to change one type of connection to another, at many online retailers (such as newegg.com, amazon.com, or other electronic supply retailers) and some retail stores, Best buy might have something, though you'd have a safer bet at a store like Micro Center which is more specialized for PC building or an alternative PC/electronic store.
To ensure you solve your problem, just be sure to familiarize yourself with the motherboard you are planning on buying (or have) and the fans you plan to have inside your computer. It can be a bit more work to check the specs on the fans and motherboards, but a little work saves hours of headache later.
3/14/2011 8:30:29 AM • Ultra Products... • Answered on Mar 14, 2011
2answers
Bought a bare bones(B 69-9005)
This problem occrus because of graphic driver related issue. For that when you power up the computer press F8 key then enter in safe mode then uninstall graphic driver from control panel then restart computer then reinstall graphic driver .Also make sure screen resolution is set to 1024*768 in display property. Let me know if you need further assistance. Thanks for using FixYa.
9/20/2010 1:10:15 AM • Ultra Products... • Answered on Sep 20, 2010
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 5 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered Yesterday
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered on Apr 13, 2024
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Can I play Minecraft in my PC?
If it is installed, probably.
4/11/2024 8:56:02 PM • Computers &... • Answered on Apr 11, 2024
Je recherche le service manuel ou diagram beringer pmp1000 merci
Salut! Je pense que c'est le manuel que tu recherches? https://www.manualslib.com/manual/214305/Behringer-Europower-Pmp1000.html
4/11/2024 3:05:34 PM • Computers &... • Answered on Apr 11, 2024
SERIAL NUMBERS DO KARAOKE VIDEO CREATOR?
You have the software, if it is not stolen or bootlegged, you have the numbers to authorise it.
4/10/2024 5:34:15 PM • Computers &... • Answered on Apr 10, 2024
Ultra Products Ultra ULT40278 XT MicroATX Tower Computer Case  MicroATX USB 90mm Fan 120mm Fan AllInOne Card ATX AllInOne Case Logo
1 questions posted
Top Ultra Products Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Ultra Products Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Ultra Products Computers & Internet
Most Popular Question
find
  • Computers & Internet
