20 Most Recent
Hawking HW2R1 Dual Radio Smart Repeater Questions & Answers
Where is ghe router 8 digit pin number for the hw2r1
Ping numbers (Or WPS numbers) are usually on a sticker on the bottom of most wifi / wireless devices. This is ONLY if they support WPS.
If you are sure the device supports WPS and a sticker is not on the bottom you may have to log into the device using a computer that is hard wired (Ethernet cable) to the device.
If you have lost the manual you can download a new one from here
http://hawkingtech.com/products/downloadfile/107.html
Note this link is for the manual to a Hawking HW2R1 ONLY.
Como resectiar unhw2r1
At the back of your device next to the WAN Port (internet port) you will find a small hole with a button inside it, turn your device off then press and hold the small button in while switching on your device, keep pressing down on the button for about 5 seconds, that will reset your to default settings.
My HW2R1 router keeps disconnecting
You need to reset router to defaults.
Also change wireless channel type to 3 or 6 or 11 then check.You can configure channel type with below method .
Press RESET button for 10 seconds it is in the back side of router then all settings defaults.
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set it as your internet service provider settings enable DHCP
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
HW2R1 repeater is providing an
Is it the repeater or the modem or router.
If you bypass the repeater does it still do it? If not then you might have to "Hard" re-set it. Check your manual on how to do it. It usually involves putting in a paper clip and/or pressing a button but each one is different. You WILL have to re-enter everything again but it's set back to the Default configuration.
If you bypass the repeater and it still happens then it's either the DSL/Cable modem or the Router. Just turn them off or unplug them for 30 seconds or so and then plug the modem in first wait until it's done then the router. Unplugging them or turning them off is considered a "Soft" re-set and just clears the temporary memory and doesn't erase anything else so no reconfiguring.
If after all that maybe it's going bad? Contact the Manufacturer and ask for more answers? They will probably ask for the Version and firmware number to know which exact model you are talking about.
I would like to know how to set up HAWKING HWDN3 USB 2.0 Wireless 300N Dish Network Adapter for Windows 10?
Have you logged into your router from a computer? Is it designed for win10 or a previous version of windows? Sounds like its for a previous version id try rolling back the driver and or using compatibility mode for what ever version of windows it was designed for. Select the app, right click and there and or in properties is compatibility mode. Ps is it your router that you updated? You'll need to log into it with a computer and RJ45 network cable. The usual network cable. And do the initial configuration like setting bssid and password Wi-Fi ect.
3/17/2019 1:10:45 AM •
Hawking...
Answered
on Mar 17, 2019
Installing a hawking HOW2R1 Repeater and setup
The Setup Wizard will now prompt you to automaticallyconfigure your IP settings (recommended) and enter asecurity key if the network you are connecting to is anencrypted network. Enter the key and click Continue.If you do not know the security key of the network you are connecting to, consult your network administrator.
6/10/2014 10:53:23 PM •
Hawking...
Answered
on Jun 10, 2014
