20 Most Recent
Relic Wet ZR11657 Watch for Men Questions & Answers
BATTERY REPLACEMENT FOR RELIC WET
If you can, pop the back of the watch off, the battery will have 3 digits, and some letters, for example
375R, 325LRW, etc. the 3 digit number is the type of battery you need.
If you cannot read the number, then typically, if you take out the battery, and you measure the width, and height of the battery, then find another battery with the same measurements, it will work, trust me.
i hope i helped!
7/18/2011 2:44:28 AM •
Relic Wet...
Answered
on Jul 18, 2011
What battery is the replacement?
Relic
Thank you FixYa.
Look on the back of the watch, or in the manual. If it doesnt say the battery size you will need to take to jeweler to have them measure the compartment to see what battery is needed. Sorry but no other way to know the battery needed.
Best regards. Jewel
9/20/2010 2:18:45 AM •
Relic Wet...
Answered
on Sep 20, 2010
How to set the 24 hr time on a women's relic multifunction Zr15992
What company made this watch? The only watch I can find with that name is not a digital watch so the 24 hour display does not possibly apply. Are you referring to the date display not changing at midnight? A quick trick that might work is to Roll the 12 hour dial forward 12 hours, (example 12 noon forward to 12 midnight).
The dual time display is for when people are using two different world time zones. For example, for people who work regularly in two different countries. Using it means you don't have to keep reseting your watch when you change countries.
Need directions to change links on relic zr77271 watch
Hello Charles Cooper and welcome to fixya.
I have NEVER even seen a RELIC watch
( and am a amateur (unpaid horologist)) but
I love all timepieces...
A quick search of the internet reveals...
A band tool...
pin pusher (search on eBay) is REQUIRED
to push the pins out of both sides of the link
you will want to remove. The FIRST/BEST tool
you will want to purchase will be at least
a 10x power jeweler's loupe (magnifier).
acekid
answer below could be EXACTLY what
you are looking for...
not GENERIC
ELSE...
You will be pushing from the SMALL end.
Generically...
this does not require a lot of FORCE but
it is WELL BEYOND any pressure any
bare handed pressing can accomplish...!!
((( pin tool MIGHT be your best choice ))).
Not really (novice) AMATEUR work...!!
Nor is it ROCKET SCIENCE...
but you would be well advised to get QUALITY
mentoring... Which would result in your purchasing
some QUALITY tools (plentiful/reasonable on eBay).
Work on a fine weave cloth & NEVER over a carpet.
Teeny screws can be found by shining a flash-light
across the floor (or vacuuming with a fine mesh cloth
inside your vacuum nozzle).
The true/best way to find your required tools
is to state your case and look on the WEB...
(Pictures really help).
Internet WISDOM is usually 80% BS & 90% just
plain WRONG (or vise versa (I can never recall)).
Good luck
WHAT SIZE BATTERY DOES A RELIC WATCH ZR15402 TAKE?
Hello Brandi M and welcome to fixya.
SR936SW (Sony) ...
which is the same as a 394 Duracell...
Which an AWI (American Watch Inst. )
cross-reference could give MANY MORE
VARIOUS manufacturer's & numbers...
Energizer 394... Renata, Varta... (etc.).
The true/best way to find your battery number
is to open the case and look...
Good luck
