20 Most Recent
Orion 076D0FH020 Remote Control Questions & Answers
URC-4640B01
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window" to get gathered related posts. .
I hv an orion t.v.
Universal remote codes are 0236, 0179, 0463 . If you need a 3 digit code, drop the leading zero.
I want to program my dish network remote to my tv
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Need codes to Orion 076NODW130 remote control
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Orion T. V. Codes
The manufacturer of the universal remotes make up the codes. Contact the maker of the remote or go to their website for the codes you need.
ORION REMOTE LOST
Orion has made Emerson,Sansui, Admiral, Memorex, RCA, Toshiba, Insignia, Akai and Zenith.
Try those codes. You can call Orion at 800 289 0980. I think the replacement remote for the FTDV2004B is less than $20.
Lost Remote
try www.partstore.com and see if they have the originald remote for your tv.good luck
