20 Most Recent Microsoft Outlook 2010 for PC (885370021134) Questions & Answers
You can have a google search to find perfect solution to your answer. A google search will provide you various solutions.
Others solutions I know is through an Imap account transfer, where you have to make same Imap accounts on both the email providers i.e, in your case apple mail and outlook 2010 and then you can safely transfer all your emails.
Next is an application approach that costs but allows you to transfer all your emails quickly with all your data safe.
One applcation is Mail Passpport pro. Here's Its link
You can go for the trial version to check its compatibilty first.
Make your choice
I hope this helps you.
Thank you
Microsoft... | Answered 2 days ago
May be possible your Pst file is corrupted .
When a PST File corrupted in Outlook there are show this type of massage as discuss above by you.
Don't worry you can recover your PST File with the help of a third party data recovery software.
There are so may software choose any of them to recover your PST file.
You can find such software from here
http://www.kerneldatarecovery.com/outlook-tools.html
Microsoft... | Answered on Jul 09, 2019
If you are searching a tool that really helps you in resolving Outlook corruption, use Recovery for Outlook PST repair software which recovers emails from broken PST and the PST corrupted due to size limitation error.
To know more visit :-
Outlook PST Repair
Microsoft... | Answered on Jul 04, 2019
Making IMAP Account
Well creating an imap account can help you.
You have to simply make imap accounts on both the email clients you use and then you can upload you emails from outlook and then download on the other hand in apple mail.
Other alternative
You can also use the software approach to solve your problem.
Various softwares/applications/third party tools are available online.
One I am aware of is Pst Converter pro.
Hope this helps
thank you
Microsoft... | Answered on Apr 29, 2019
Either delete the *.pst file and let Outlook re-build it. Or try running the "office repair" on outlook. Also a complete un-install, run a files cleanup from systems tools followed by re-installing Outlook might help.
There might be some *.pst repair tools out there but they probably cost money.
Microsoft... | Answered on Jan 30, 2019
Moving emails from outlook mac to outlook windows is a complicated process as both the platforms are totally independent of each other and does not support each others file formats. Outlook mac supports only olm database files whereas windows outlook only supports pst. Though there are pleanty of methods available like IMAP file transfer etc but the direct and most fruitful method is to simply convert olm file to pst format so that it can be imported in windows outlook. You may employ OLM to PST Converter Pro for conversion process and then import pst into windows outlook to move emails.
Microsoft... | Answered on Nov 28, 2018
technical errors are also quite obvious like every other man-made thing. Upon coming across with any such issue, the best recommendation can be to connect with the Microsoft outlook support phone number. They can thoroughly solve all these issues. Prime reasons making Microsoft Outlook so much popular around the globe are:
Microsoft... | Answered on Oct 22, 2018
Si desea activar Microsoft Office 2010, puede ir a http://www.instructables.com/id/C%C3%B3mo-Reparar-Error-0xC004F074-De-Microsoft-Word/ que tiene una clave de activaci?n. Key es muy barato y es un verdadero compartir experiencias despu?s de comprarlo para you.I han comprado all? por varias veces, la esperanza puede ayudarle.
Microsoft... | Answered on Jun 08, 2016
Hi Tami,
You can fix your Outlook problem with the help of Scanpst.exe .
With The help of Scanpst.exe you can repair your pst file just run the program and if everything is ok you can recover your PST File and after taht you can open your Outlook without any problem.
As The .pst file corrution is the problem of your not opening Outlook so after the pst repair ther is no isues .
If you did not repair your .pst file with help of Scanpst.exc program don't worry there so many third party data recovery for Outlook PST you can also try this type of software one of them which is personally used by me is Kernel for PST Repair you can try this software from here
http://www.pstrecoverytool.net/
Microsoft... | Answered on Mar 12, 2016
Are you using the current release of Adobe reader?
Microsoft... | Answered on Feb 08, 2015
Open outbox. Right Click message. Option for delete should pop up.
Microsoft... | Answered on Dec 16, 2014
Sounds like your Email has a set up issue. Check the Receive email setups under options. Make sure that you are able to receive BCC emails.
Microsoft... | Answered on Feb 28, 2012
If you cannot fit your PST file backup on a single drive please try choosing "Compressible Encryption" as the format to save as. This will reduce the amount of space needed to back up your PST file.
If it still won't fit then try backing up to a network drive.
Please let me know if this helps and rate my answer.
Many thanks,
Chris
Microsoft... | Answered on Mar 02, 2011
Microsoft Outlook 2010 for PC (885370021134) Logo
28 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
migrate email data from outlook 2011 mac
  • Computers & Internet
