20 Most Recent Planar PDP-42BK 42 in. Plasma HDTV Questions & Answers
You must replace the drivers, the output/chopper transistors and use the correct type of R2/3 resistors otherwise you have a fire waiting to start.
Planar PDP-42BK... | Answered on Feb 26, 2017
Change the display resolution through the menu.
Planar PDP-42BK... | Answered on Apr 15, 2014
I have a 42in Flat screen tv with a cracked screen made by Viore
Planar PDP-42BK... | Answered on Nov 13, 2011
Hello
No. Ofcourse not. What are you saying. Smoke over the TV!
Switch it OFF. There is something wrong with its internal circuit. Any capcitor or resistor burns. Cannot troubleshoot remotedly to this fault. Plasma TVs may heat up to an extent, and there will be fans at the top of them to **** out the heat produced while it works. Look, whther the fans are working. If not replace them or findount the reason.
A plasma Tv; whatever old it is; won't blow out smoke at all. OK.
Planar PDP-42BK... | Answered on Oct 20, 2011
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Planar PDP-42BK... | Answered on Jan 23, 2010
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Planar PDP-42BK... | Answered on Jan 01, 2010
Your DVD player may have up to 3, sometimes 4 audio OUTPUTS. Labeled as "bitstream" which is a digital coaxial cable, another labeled as "optical" which is a fiber optic cable. Depending on the model there may also be as many as 2 different types of analog outputs, one is a 2 channel composite connection, or otherwise known as RCA and another is labeled as "multichannel out."
Your television will have audio inputs on the same panel your video cable is connected from the player. Connect to those from the player.
Planar PDP-42BK... | Answered on Dec 26, 2009
Most likely the lower y-buffer board which is mounted to the left of the panel in the back of the TV is bad. I believe you can get LG equivalents for these boards. There should be part numbers on the board itself..
Planar PDP-42BK... | Answered on Nov 11, 2009
Try these things.
1) As much as I hate to say it, most of the time devices that aren't turning on are not plugged in. If the device is unplugged, plug it in. (Sorry)
2) Check the outlet. Plug in something that you know works into the same outlet. If it does not power on, check that there are no flipped breakers in your breaker box.
3) Some outlets/breakers have a red Reset Button on them that needs to be pressed to reset the amount of charge in the outlet.
Hope some of those helped.
Planar PDP-42BK... | Answered on Sep 03, 2009
hi waldo1599. try this link. it was a solution given by with the same prob as yours..thanks for using fixya. hope it helps. let me know how it works. if it wont, we'll find another way.
http://www.fixya.com/support/t598172-planar_pdp_42bk_42_green_light_just
Planar PDP-42BK... | Answered on Jul 15, 2009
I have over 10 years experience in electronic tech support. Currently I work for Viore customer service. Our customer service phone number is 216-454-0868.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The repair will cost a minimum $250 to $300 with parts and labor. If you're interested in going forward with repair, take the TV to a repair shop in your area to have the problem diagnosed. The tech will give you a copy of the work order showing the part(s) needed to complete the repair. Then you'll call the above number and ask to speak with Raphael at ext. 3115. The work order will be forwarded to the corporate office and they will contact you with the price of the replacement parts. You will be charged for the parts directly to avoid any markup by the repair shop. The part will be shipped directly to whatever repair shop you choose.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Planar PDP-42BK... | Answered on Jun 18, 2009
Check the 15v line that runs through all the boards, left, right and top.. If that has no power, then look on the ysus board (left one) there is a flyback reg (5pin) standard to-220 case surrouded by caps, it does dc to ac conversion, if you dont have the 15v output then the chip is bad. I just did 2 of these that had the same problem.
Planar PDP-42BK... | Answered on Apr 02, 2009
Take it back to the dealer from which you purchased, receipt in hand and raise a stink.
Planar PDP-42BK... | Answered on Mar 05, 2009
Hi there
Try to reset the TV back to factory state, this may resolve the issue for you, also leave the TV off and disconnected from the mains for 20 mins or so.
If this does not work you may have to have the IC board repaired again
good luck and kind regards
Planar PDP-42BK... | Answered on Feb 07, 2009
Planar PDP-42BK 42 in. Plasma HDTV Logo
53 questions posted
Top Planar Televison & Video Experts
Marvin
Marvin
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Televison & Video
Most Popular Question
tv turns off will turn off right away
  • Televison & Video
