20 Most Recent
Sennheiser Sennhesier MM 100 Bluetooth Stereo Headset Neckband Wearing Style (504111) Questions & Answers
I have bluetooth headset MM100
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
I have the Sennheiser HMD 280 PRO Professional
You have to wire the plug to eliminate the voltage sent by the sound card. I can't remember if it's the tip or the sleeve, so you'll have to verify with a volt meter. Use a 3 position plug to solder to the mic wires, just don't connect the wires of the mic to the one that has voltage on it
Sennheiser MM100 bluetooth not working
Yes I had the same problem.
Under some circumstances the MM100 freezes (didn't figure out when just yet).
It's a software issue inside.
Solution: open left speaker (the side with the charge connector and hence the battery).
Discharge the battery (or just short circuit for half a second) and it works again.
Sennheiser should built a reset button on these things.
