20 Most Recent
Sanyo R227 WiFi FM Radio Questions & Answers
No power sanyo r227
I had the same problem. A defective capacitor is trying to charge near the audio chip . My solution : I have remove the audio chip (the one with big heat sink) and I use the aux out output to my amplifier. When plugging it takes some time to finally work : but once plug and working it stays on and work ok.
My sanyo r227 internet radio just flashes quickly
Flashing is caused by bad capacitors Caps on power supply board all go bad sooner or later, so replace them all ($5). Look for bulging tops especially, and the green ones are the worst. Power spike could have caused poor quality caps to fail. Don't want to fix it, sell it to me.
No power sanyo r227
Could be bad capacitors or fuse. Fuse is inside under a plastic cover as I recall. Caps on power supply board all go bad sooner or later, so replace them all ($5). Look for bulging tops especially, and the green ones are the worst. Power spike could have caused poor quality caps to fail. Don't want to fix it, sell it to me.
Cal I bye a new or referb power supply board?
If you can get a refurbished power supply board, buy it. They are as good as those new from factory. I bought a refurbished Sony Radio - Cassette - CD player 23 years ago and it's still good!
Scematic for sanyo r 227
You'll never get this from them, as others have tried. Sanyo is now Panasonic (Matsushita). Also sold under the Medion name (in Europe I think).
Sanyo r227 flashes when plugged in
Most likely bad capacitors on the power supply board. Replace them all (6 or 7). Same thing happened to mine. If you see green capacitors (KSC brand) they are definitely bad. Notorious for failing. Cost about $4 for me as I do it myself. Don't want to fix it yourself, sell it to me.
