20 Most Recent
Planar XP15SSA-01 15 in. LCD Television Questions & Answers
Lost original power source. tried
Power source probably incorrect, Sounds like it too little and cant keep the screen lit. There should be a label on the back that will tell you the input Amps and Voltage or look at the connection and see if it has the voltage inscribed somewhere on it. Best of luck.
5/12/2011 1:20:55 PM •
Planar...
Answered
on May 12, 2011
When i turn the tv on the volume is stuck all the
Muting is not designed to lower volume it shuts it off completely That;s why it resets when turned on and off.
Unless by muted you mean you can lower the volume to a listenable level but it reverts to full when you restart it.
Try using settings and set the volume and the type of sound(mode) you want then when you exit the menu it sshould save those settings.
Please rate my help++++Thanks for using FIXYA
5/16/2010 11:14:02 PM •
Planar...
Answered
on May 16, 2010
Ir codes
What is the brand name to your TV? Provide more details please. If you wish to get more details, surf this link.
There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help.
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
I need a replacement remote control for JVC NX-BD3 network media system
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy.
What is the universal remote
To setup so a firestick could control my Mastertech tv when I tried element from the brands to choose from it worked like a charm for on/off control, volume and mute controls from the firestick. So you might try using Element as a brand or the codes for Element tv's. BTW, I went through several brands before I landed on Element which worked.
