20 Most Recent
Planar XP17W 17 in. LCD Television Questions & Answers
Green Light on black screen
These units have the power supply and ballasts on one board, It's common for the capacitors on them to fail(bulge, leak, pop), those are the visual ques that they are bad, i've had good luck replacing the capacitors on this model to save them from the trash.
inspect C20, C21, C34, C37, and C36, they are all the largest caps on this board that the power cord plugs into.
Green Light on no picture
More than likely, the planar LCD sets have a set of 5 1000uf 16volt caps that fail. There could be other problems, but to check, unplug, pop off the cover, and look at the brown cannisters. They will mostl likely be bulging, or you may see blackish goo coming out of them. They're fairly easy to replace if you have experience with a soldering iron.
Planar XP17W 17"
The power supply ballast board has 5 1000uf, 16 volt capacitors that fail(you will likely see them swelling, or leaking), These are common cap's.
This can either cause the backlight to not work at all, light temporarily, or display no picture, but still give you sound.
BCF
Ir codes
What is the brand name to your TV? Provide more details please. If you wish to get more details, surf this link.
There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help.
My replacement rc-518m remote control is stuck in TV mode how do I get back to a/v
It may be necessary to take the remote apart and clean the contacts with rubbing alcohol and a tissue on the board that is inside. If that doesn't fix it, a replacement is necessary at Ebay.com https://www.ebay.com/itm/394877786274?itmmeta=01HT47X6X7WE749Y2CMG3NX54S&hash=item5bf08cd8a2:g:7pQAAOSwn7BlAn8h&itmprp=enc%3AAQAJAAAA4OMK5%2BdFWZwJQhIS5nEQ3eO7C2zq5QRICeu%2BbPKwqrfkc8con3byi0%2BbabcDYrBTOEyKclvkbzHrOJ1lVMfwduYTPcx0fAcW5XmaZ3ZRWS1%2FnVxMUIwno%2BPNUVuNqN%2FCSDJJ3gG2hQ%2BbGGyfUiO2ppgtjsvtiihnrClntKtSssM8RikHgpG8y9SjAz6z0V0GPkVJf6gypymGRdzz4HfuNn%2BkiMmAXp2NHVWpP6xfbghej%2B1MkOgqhJxV4V1B%2Bp8wVx%2BKV36M%2FVEdzoejZajCMt9ApRe1beW4a0rCXTdGZRuV%7Ctkp%3ABFBM2u70h9Fj
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
I need a replacement remote control for JVC NX-BD3 network media system
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy.
