20 Most Recent
NexxTech N2000 Questions & Answers
Nexxtech n2000 The manual says CD-R with "Digital"
I'm pretty sure it actually says something to the effect of "These discs are marked with "Digital Audio" and the logos shown below...', the operative word being AUDIO.
DATA discs do not work on a consumer CDRecorder.
I can not input "yes" nor "no" as an answer to a
This can happen if you actually cannot finalise the CD like if the burn was "Bad" OR other times it IS actually a "Fault" within the unit itself.
If you can "Factory reset" then try that. Try another "Brand" of CD, DVD.
try doing it again, it may just be a "Glitch".
However if after doing all this and it still gives this message every time you finish a "Burn" then indeed you have a logic fault, and the unit will have to be repaired.
I have 2 of these and it seems that they do not
Hi Clem.
The problem is likely the lens. If you like you can try disassemblying the unit and accessing optical drive lens. The lens are cleaned using soft QTips and CD cleaner solution (or isopropyl alcohol).
If that does not help, try contacting the seller below to see if a replacement drive is available.
NEXXTECH Replacement PartsNote: A firmware update should also be performed. Finding the right update for this units is often impossible, and you cannot risk installing the wrong firmware from the Internet. For that reason I did not mention this.
8016806
go to manufacturer's website, look for support/downloads.manuals
