20 Most Recent
Sony MEXBT2800 AMFMCD Car Stereo Receiver with Bluetooth Questions & Answers
I have a Sony Eplod
Just pull the face-plate off and smack it 5-10 times (don’t break it but smack it hard enough ;))...
This usually happens when one of the keys is stuck (usually the source button)... I had this issue, tried many things for almost a week, then somewhere about this smacking idea (I think on YouTube), and walaaa it worked like a charm.... Bluetooth, memory buttons and all
Sony xavw1
Open the device and check your belt it may be loos when you want to not change your belt insert a cd alway
I bought the Sony Xplod
How about you take it back to best buy...even if you lost the receipt they should still exchange it
Hello i have a sony
Make sure you hold down the Bluetooth button for long enough. I found I had to hold the button for 20 seconds, until the unit entered Bluetooth pairing mode.
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
- Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
- Check the audio cable for any signs of damage or wear.
- Make sure the auxiliary input is selected as the source on the head unit.
- Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
What is the correct way to hook up a 1000 watt Sony xplod Amp with 1 subwoofer to my Sony mp-40
To properly hook up your 1000 watt Sony Xplod Amp with one subwoofer to your Sony MP-40, you will need to connect the subwoofer to the amplifier using RCA cables. Once the subwoofer is connected, you will then need to use a power cable to connect the amplifier to your Sony MP-40. Make sure the power cable is connected properly and that the amplifier is turned on. After that, you should be able to adjust the settings on the amplifier to get the desired sound from the subwoofer.
