20 Most Recent
Goodman GPH1324H21A WallWindow Air Conditioner Questions & Answers
My AC keeps freezing up
Hello, the unit will freeze up either due to a airflow problem, suchs as dirty filter, dirty evaporator coil. Or a low refrigerant charge
7/6/2012 8:12:50 PM •
Goodman...
Answered
on Jul 06, 2012
I just registerd my unit and the deler name I put
Under the circumstances you outlined, it may be better if you call. To speak with a Goodman Heating and Air Conditioning Consumer Affairs Representative
from within the United States, call 1-877-254-4729.
2/28/2011 10:13:00 PM •
Goodman...
Answered
on Feb 28, 2011
Heat strip keeps tripping breaker after running
Breaker must be 2 to 3 times of running amps of a/c or heater whichever is higher. If breaker fixed minimum3 years back, better to replace. In heater, clean heater strips by a blower and also check for loose contacts. Sometimes weak strip element, it may happens. Replace heater element. Thanks.
1/29/2011 3:02:26 PM •
Goodman...
Answered
on Jan 29, 2011
No hot air
Check your thermostat setting to +29 and also mode " Heat" And still problem write clearly.
12/13/2010 8:36:03 AM •
Goodman...
Answered
on Dec 13, 2010
Air conditioners drain pan keeps
saleslong says:
I have not had this issue in the pass, what could have caused the problem of the pan filling up and not draining
rejakwilson says:
I Feel 99.6 % Sure that you Will Fing that this IS tour Problem The UNIT COULD Have "SETTELED" and Setteled to an Improper angle
You ALSO Should Take a LOOK INSIDE the Unit at the Lower Pannel Spacificly Around the DRAIN AREA for DEBRIS Build Up that WILL ALSO HINDER its Ability to Drain Properly
Chech the Leveling and Be Sure that you Have And BE SURE IS Is Set Up To TILT TOWARDS the DRAIN Opening Again
I am Confedent that these Answers WILL Lead you to Correcting this Very Problem. LAST and IMPORTANTLY Be Sure Your Drain Hose Goes "DOWNHILL" ALL THE WAY FROM UNIT o the Outside.
6/17/2010 9:20:56 PM •
Goodman...
Answered
on Jun 17, 2010
