20 Most Recent Fahrenheat F2545 Electric Baseboard Heater Questions & Answers
My furnace will not light.. replaced the ignighter and flame sensor
Check the gas valve for a reset. It could be either a push button or a pull tab.
3/19/2013 8:48:35 AM • Fahrenheat F2545... • Answered on Mar 19, 2013
2answers
Bought a Fahrenheat 5' baseboard heater and a
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
11/22/2011 8:22:24 PM • Fahrenheat F2545... • Answered on Nov 22, 2011
I have a model UP2422B wall heater that glows very red when it first comes on and before the fan can kick in and cool it down. Is there a replacement heater available of the same size?
These heater elements should never glow red. The fan should come on at the same time the heater elements get power to heat up. If they turn red, the fan isn't starting fast enough, or is just turning too slow. Think of it like a toaster. They glow red but if you blow on them, they cool down until they aren't red anymore but they are still hot. I have this same heater. In the fan end opposite the fan motor, there is a little brass bushing (bearing) on the fan shaft that's mounted inside a rubber mount. Pop the rubber mount out of the heater housing, clean it up with degreaser and put grease or a heavy duty oil on the shaft and reassemble. If it still turns slow after that, it needs a new fan motor. You can probably match it up with the same motor from McMaster Carr or Grainger for cheaper than from Marley. I hope this helps
11/26/2023 2:02:20 PM • Fahrenheat... • Answered on Nov 26, 2023
My Fahrenheat Model FHP1500 will not heat. What can I do?
What is this? please give exact details.
4/12/2019 12:11:43 AM • Fahrenheat... • Answered on Apr 12, 2019
Fahrenheat mmhd1502ta loud buzzing
You may have to put a few drops of machine oil on the motor shaft. There is a felt washer on both ends of the motor shaft that absorbs and stores the lubricant. It probably is dry.
10/22/2016 9:02:56 PM • Fahrenheat... • Answered on Oct 22, 2016
I bought a Fahrenheat FZL4004 replacing an older model) and it wont stay on. It comes on, heats, blows, clicks off, & must be manually reset in order to come on again. Help?
Here is the link for the owner's manual. Or call customer service at 1-800-654-3545. http://www.manualshelf.com/manual/fahrenheat/fzl4004/instructions-assembly.html
3/1/2015 7:09:57 PM • Fahrenheat... • Answered on Mar 01, 2015
Fahrenheat md26r
This thermostat is a DPST (Double Pole Single Throw) type meaning it will switch BOTH pairs of wires either ON or OFF. It is a type used primarily for 220 - 240 volt circuits and can switch up to 22 amps of load current. Most heaters will provide a wattage rating and some also provide a current rating as well. Since most electric heat circuits are connected to a 2 pole 15 or 20 amp circuit breaker (or fuses) via #12 copper wires it should work well. If connected to a circuit greater than 20 amps - as long as the heaters connected to the circuit do not draw more than 22 amps will also work fine. If all is well so far, the continue. The thermostat should have 4 wires. Two of one color, two of another (black and red are common colors). One color group will be the LINE (powered) side, and the other group is the LOAD (heater) side. You should verify WHICH color group is which for best results. The switch will open and close a connection between the LINE wires and the LOAD wires. The thermostat should be installed in an electrical switch box located on an interior wall at about 5 feet high and not above any heater or heat source. Do not locate it behind a door that swings open, etc. The box should be supplied by a circuit from the electrical panel that will connect to the LINE side color group wires *and* a circuit that will extend from the thermostat's LOAD color group wires to the heater's wire connections / terminals. If running common #12/2 (for a 20 amp circuit breaker) or #14/2 (for a 15 amp circuit breaker) romex cable from the panel will have the Black and White wires connected to the thermostat's LINE wires and the Black and White wires in the #12/2 or #14/2 romex cable from the heater will be connected to the thermostat's LOAD wires. The ground wires will connect to each other AND a short length of the same size wire should be run from this same point to each: the ground terminal screw of the thermostat and (if using a metal electrical box) to the electrical switch box with a separately purchased green ground screw designed specifically for this purpose. Plastic boxes are not grounded. Leave a comment if you have other questions & good luck!
12/10/2013 2:31:35 AM • Fahrenheat... • Answered on Dec 10, 2013
0answers
Plf1504d wireing
Be the first to answer 10/20/2013 4:46:18 AM • Fahrenheat... • Posted on Oct 20, 2013Be the first to answer
Fahrenheat F2545 Electric Baseboard Heater Logo
Popular Tags
2 questions posted
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Paul Katynski
Paul Katynski
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Fahrenheat Heating & Cooling
Most Popular Question
furnace will not light replaced
  • Heating & Cooling
