20 Most Recent K and N Yamaha Big Bear Yfm350fw Air Filter Questions & Answers
1998 big bear350 high idol want adjust down
did you set the float height correctly? It still might be flooding some also.
11/24/2014 9:57:13 PM • K and N Yamaha... • Answered on Nov 24, 2014
3answers
Why is my 2003 Yamaha
That sounds like it is running too lean. You may need some carb adjustments to account for your altitude.
11/10/2014 4:24:04 AM • K and N Yamaha... • Answered on Nov 10, 2014
Can you clean the brushes and contacks in yamaha atv starter
Let it sit out and dry for a few days if that doesnt work wd 40 the hell out of the starter . If no resolve , replace.
5/28/2014 9:12:37 PM • K and N Yamaha... • Answered on May 28, 2014
I have a 2003 warrior
Replace the starter relay
4/20/2014 3:47:58 PM • K and N Yamaha... • Answered on Apr 20, 2014
No spark cdi yamaha moto-4
oppss ... you need factory service manual for cdi and other resistance specifications
4/13/2014 4:07:53 AM • K and N Yamaha... • Answered on Apr 13, 2014
Clean out a yamaha big bear carburetor
remove screw or large hex head plug in bottom of carb..drain and replace screw or plug.. . A K&N must be clean, lightly "oiled",, and dry..
4/13/2014 2:58:49 AM • K and N Yamaha... • Answered on Apr 13, 2014
I have a yamaha big bear 350 engine bogs down when climing a hill
Could be a problem with a bad float that is overloading the engine with fuel. Does it take a little bit to "clear its throat" once you are on flat ground again?
3/7/2014 1:37:49 AM • K and N Yamaha... • Answered on Mar 07, 2014
Can a 25/8/12 front atv tyre fit on the rear rim
the outside diameter (25) should be the same. the 8 and 10 is the width. 8 is prob too narrow to fit on a 10" wide rim. fyi, 12 is the rim diameter.
2/10/2014 4:42:22 PM • K and N Yamaha... • Answered on Feb 10, 2014
Carb leaks
bowl float is stuck or the bowl gasket is bad
2/10/2014 4:40:11 PM • K and N Yamaha... • Answered on Feb 10, 2014
Yamaha350motoatv
prob just need to replace it.
2/10/2014 4:35:01 PM • K and N Yamaha... • Answered on Feb 10, 2014
I have a 2003 Yamaha Big Bear 400 4x4. When I try
selinoid switch or starter
11/6/2013 3:57:26 PM • K and N Yamaha... • Answered on Nov 06, 2013
4 wheeler starts and idles well, but once warmed
may hav worn ignition parts that are gittn hot--they gain resistence-test them with a ohm meter--clymer manual has procedure
11/6/2013 3:08:47 PM • K and N Yamaha... • Answered on Nov 06, 2013
Atv big bear 350 won't idle after cleaning
sounds like your mixture was leaned out because ur filter was cloged up ...making it run rich so was adjusted by screwing air screw out, now uv cleaned it, adjust it to make mixture richer by screwing back in until runs smotherly
10/5/2013 10:32:08 PM • K and N Yamaha... • Answered on Oct 05, 2013
K and N Yamaha Big Bear Yfm350fw Air Filter Logo
49 questions posted
Top K and N ATVs Experts
john h
Renee Knafel-Bullock
ADMIN Andrew
ADMIN Andrew
Are you a K and N ATV Expert? Answer questions, earn points and help others
View Most Popular
K and N ATVs
  • K and N ATVs
Most Popular Question
4 wheeler starts idles but once warmed
  • ATVs
