20 Most Recent
Proview HV-207 20 in. HD-Ready LCD Television Questions & Answers
Need a remote code for Proview HV207
These are the setup codes for Proview brand TVs with GE universal remote control. If you want to know more codes and other details, check
this link. Check these codes first.
1025 1026
Need user manual
Try to locate the makers internet site or Google the model number with "manual" to try to locate it yourself.
Tv proview hv207 problem
DON'T EVER BUY PRO VIEW!!!!! THEY SELL JUNK AND THEN CHARGE A TON TO FIX IT...................
I called customer support and they said it is the receiver. I can't find one and they want $190 to fix this 1 1/2 year old TV. Mine is not digital so I can't receive broadcast in a year so mine is going out in the trash.
No they want sell parts. You can cut your losses or give them them more money. Good luck.
Trying to connect antenna. Tv
Sounds as if you have a bad tuner. Can be tricky to replace if it is on a 2 sided board. If you are not comfortable with a soldering iron or electronics, I would have a certified servicer look at it.
I purchased at yard sale.
Look at the power connector on back of set. You will probably see 3 recessed prong's. You should be able to use the same type of cord as on a computer or monitor. You can get one at
any home center or electronics store like Walmart, BestBuy, hardware stores, etc.
When I turn my tv
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly. The capacitors are blow and once replaced this will fix your issue.
Hope this helps :)
Daughter put tv on av
have a look to see if the channel it should be on to use as a tv is still on channel 3 or 4.
My remote control for my
Call Encompass Parts Distr 1-800-638-3328 Also look on back of TV for correct Model number give that # to them and Mats Electronics is another company 1-800-628-1118
The touch screen is not
Hi
Thanks for using FixYa. If your remote isn't working then check for batteries in the remote, replace them. And, if you want to buy a new or replacement remote then you can visit this link--
Proview HV207 replacement remote
Proview HV207 Orignal OEM remote
And, if you have any other issue then please elaborate and descroibe the issue briefly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Proview LCD TV
I am having the same problem. If I play with the power button on the back it will come on sometimes. I was looking for a solution here but looks like I will have to take it apart and check for loose solder joints.
