20 Most Recent
SVA-USA EV-1703 17 in. LCD Television Questions & Answers
SVA EV-1703 Manual
You can use a laptop charger, as long as the connecter to the TV fits it'll work. I'm using one for my old set. I bought it from the Salvation Army for $5 without a power cord.
Hope this helps!
Picture goes out after 2 seconds
Tv have picture only few sec.than dies have sound left only?Yes,than the tv long board call the LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy this long LCD inverter board for the replacement.
The power went out and having trouble getting tvto
This is the best solution for your problem as a 40 year experience with wires etc.
Go to the source of your cable signal connector .
Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.
Vitally
SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
Only get a few channels
try these people as i hear they are good. The Office of Research Services at The University of Georgia
P. O. Box 2187 ? Athens, GA 30612 ? Phone: 706-542-2411
We understand that your problem
some universal remotes are used only tv play.they did not open menu .so you bought original remote and solve your problem. thank you.
10/11/2010 8:06:53 PM •
SVA-USA...
Answered
on Oct 11, 2010
I have a small sva
With remote access the user menu and then Turn off the ' Closed Caption ' feature.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/16/2010 5:31:49 PM •
SVA-USA...
Answered
on Jun 16, 2010
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
