20 Most Recent
LG VX9200 Cell Phone Questions & Answers
Im locked out my phone
you can try to do *22899 which will sometimes reset it to the last four of your phone number
if this does not work, take it to the verizon store and ask a rep to hook it up to the PST machine and get the code for you, please find a knowledgeable rep to do this
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
The screen of my lg-vx9200 isn't working, what should I do?
Hello, problem is from the flex. The flex is connected to the screen. Sometimes the flex worn out and the screen won't display. The flex is connected to the phone board. This is common with flip and slide phones. The flex worn out as a result of constant opening and closing of the phone.Have the flex replaced and phone display should be restored.Regards.
Hi my name is Brian,
You will have to replace the lcd on it or try to get a warranty thru verizon. I have repaired alot of these and its a common problem. The outer screen is still working if it is then you will have to get it replaced.
How come my LG Env3 only displays the Verizon logo?
There are a few possible reasons why your LG Env3 is only displaying the Verizon logo:
- The phone is stuck in a boot loop: This can happen if the phone's software becomes corrupt, causing the phone to continuously reboot and display the Verizon logo.
- The phone is stuck in a firmware update: If the phone was in the middle of a firmware update and the update failed, it may be stuck in a loop and only display the Verizon logo.
- The phone has a hardware issue: If the phone's hardware has become damaged or malfunctioning, it may only be able to display the Verizon logo.
- The phone is locked: If the phone is locked with a passcode or pattern and you've tried to enter it multiple times, it may display the Verizon logo.
If you're unable to fix the problem by yourself, the best solution would be to contact the manufacturer or the carrier to get the phone checked.
It is also possible that the phone was previously owned by someone else, it may be locked to a carrier and the only option is to contact the carrier and ask for assistance
May have blocked number how do i unblock
On the android system go to phone and recent and locate the number and select it by touching it for a couple of seconds you should get a menu that comes up and says block/unblock. If the number is not listed or block is the only option then it is not blocked
10/24/2016 10:29:40 AM •
LG VX Cell...
Answered
on Oct 24, 2016
