20 Most Recent
NEC DT730 Phone Questions & Answers
I need to find out how to change the display
Dictionary.com offers a free translator where you can type in words and get the same word in many different languages. Just type what you see on the screen in the field of the translator and hit the translate button in order to navigate through the menu to change the language.
OR if you still have the user manual, im sure there are pictures of the phone inside that show the steps of changing the language and you can guess your way in?
I have a red flashing light on a NEC DT400, it is the reception ext key. How do I cancel it out?
To cancel the red flashing light on the NEC DT400 associated with the reception extension key, follow these steps:
Hold the Exit Key: Press and hold the Exit key.
Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option.
Choose "All": From the available options, choose "All".
This should help resolve the issue related to the reception extension key. If you encounter any further difficulties, consider referring to the NEC DT400 User Manual or contacting your NEC Authorized Supplier for additional assistance.
How can i fix message 14 on nec sl1000
To address Message 14 on the NEC SL1000, follow these steps:
This should help resolve the issue related to Message 14. If you encounter any further difficulties, consider referring to the NEC SL1000 User Manual or contacting your NEC Authorized Supplier for additional assistance.
HOW TO FIX TIME AND DATE FOR TELEPHONE SET NEC MODEL IP2AP-12TXD TEL2(WH)?
There is a post here: https://sundance-communications.com/forum/ubbthreads.php/ubb/showflat/Number/242170/Searchpage/2/Main/42698/Words/time/Search/true/time-change-this-weekend#Post242170
SV8100 and IPKII systems
From any display phone
With the phone hung up [idle]
Press SPEAKER
Dial 728
Using a 24 hour [military] format
Dial 2 digits for the hour
Dial 2 digits for the minutes
Press SPEAKER to enter the change / end
Only the InMail voice mail clock is controlled by this clock setting. All other voice mail products will have a separate clock.
Electra 8/24, PROI, PROII, Elite, & Elite IPK Systems
From the station connected to port 01 or 02 of the system
[Usually that is the attendant phone; ext 10, 11, 100, 101]
Press FEATURE [or FNC]
Dial 9
Press #
Enter the hour and minute via the dial pad
Press RECALL to change to am / pm as needed
If you only need to change the clock setting
Press FEATURE [FNC] to end
If you need to change the date as well continue
Press HOLD
Press RECALL [repeatedly if needed] to scroll through to select the day of the week
Press # to move the cursor to the day of the month field
Enter the day of the month via the dial pad
Press RECALL [repeatedly if needed] to scroll through and select the month
Press # to move the cursor to the year field
Enter the last 2 digits of the year via the dial pad
Cheers from Atcom
https://atcomsystems.ca
Can NEC DTU-16D-1A be used with a standard PSTN line in?
Yes, the NEC DTU-16D-1A can be used with a standard PSTN line. You will need to program the phone system to recognize the PSTN line instead of the ISDN2 line. Here are some steps you can take:
- Access the programming mode on the NEC Xen Alpha system by pressing "Speaker" and then "7" on the main phone.
- Enter the system password, which should be provided in the user manual or by your system administrator.
- Press "Speaker" and then "3" to enter the line programming mode.
- Scroll through the line options using the arrow keys until you find the option for PSTN. Select this option.
- Save your changes by pressing "Speaker" and then "Store".
Once you have completed these steps, your NEC DTU-16D-1A handsets should be able to connect to the PSTN line and function properly.
How do I delete all auto attendant messages including day/night mode, opening inbox, schedule 1, schedule 1 intervals a/b/c?
The steps to delete auto attendant messages, including day/night mode, opening inbox, schedule 1, schedule 1 intervals A/B/C, will depend on the specific phone system or software you are using. However, here are some general steps you can follow:
Access the auto attendant menu: This is usually done by dialing a specific extension or accessing the system through a web-based portal.
Navigate to the message management section: This section may be labeled "Greetings," "Prompts," or "Recordings," depending on your system.
Select the message you want to delete: This may involve listening to the message or selecting it from a list.
Choose the delete option: This may involve pressing a button or selecting a menu option.
Confirm the deletion: Some systems may require you to confirm the deletion before it is finalized.
Repeat for all auto attendant messages you want to delete.
It's important to note that deleting auto attendant messages may affect the functionality of your phone system
