20 Most Recent
GE 29875GC1 Digital Answering Machine Questions & Answers
How do I retrieve messages
The remote access instructions are on page 18 of the manual at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
How do you set the clock?
Press and hold the STOP/SET button for two seconds to enter the change mode. Full instructions are in the "Changing the Settings" section beginning on page 10 of the manual at
How do you change the time on the machine.
Hold down the STOP/SET button for two seconds to access the change mode. Full instructions are in the "Change the Settings" section beginning on page 10 of the downloadable manual at
How do I erase an old welcome message and put a
Press and hold the GREETING button. Record your message after the beep. Release the button when down.
If you need a manual, you can download one at
http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
IT ONLY RINGS TWICE BEFORE KICKING IN - HOW DO I
Press and hold the STOP/SET button for two seconds to access the menu. After the language and time/day you can change the rings to answer.
Full details are in the "Changing the Settings" section of the manual, starting on page 10. If you need a manual, you can download one at
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
