20 Most Recent EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer Combo with Adapter Kit - CWD1510WKIT Questions & Answers
I have E64 error code and door remains locked
Heater Open Circuit. Heating element or wiring defective Check heater coils and connections for open circuits. Replace heater and/or wiring
7/13/2015 10:34:57 PM • EdgeStar 2.0 Cu.... • Answered on Jul 13, 2015
Edgestar e30
E30 is a door locking failure. The unit attempted to lock the door several times without success. First, make sure your door is closed firmly. Check for anything that may be blocking the door latch. Check that the latch is aligned to the door lock. Unplug the unit for 30 minutes to reset the electronics. If the unit still does not lock, please contact Edgestar at 800-297-6076.
4/2/2015 7:55:44 PM • EdgeStar 2.0 Cu.... • Answered on Apr 02, 2015
Balance systems or shocks broken. GE Spacemaker has broken stabilizers.
GE Spacemaker is a generic range of appliances. All questions in Fixya need full 'make model (what it is)', first 3 words. If the stabilizers are broken Google for parts. GE (numerical model number) Parts https://www.google.com/search?q=GE+spacemaker+parts Depending on age, they may no longer be available ..
4/15/2024 7:28:59 PM • Washing Machines • Answered 3 days ago
Dear sir, I have Primus MB205 washer extractor problem. It shows error out of order, ask for service (error 301: mits 0c2)
Question edited for spelling. You will have to do what it says and call for service. This is a Commercial Machine and not popular in North America where we are. https://www.google.com/search?q=primus+mb205+washing+machine The error is not listed anywhere https://www.google.com/search?q=error+301+mits+0c2 ..
4/14/2024 5:20:05 PM • Washing Machines • Answered on Apr 14, 2024
WASHER EXTRACTOR PRIMUS MB205 OUT OF ORDER SHOW ASK FOR SERVICE ERROR 301 MITS. 0C2
Code 301 relates to a drain failure. The rest of the code may relate to specific parts. I find no explanation available for the remainer of the code. It is likely only the manufacturer can say what that refers to. https://primuslaundry.com/en/contact
4/14/2024 11:12:07 AM • Washing Machines • Answered on Apr 14, 2024
Lay out of water tubes. I have taken apart but forgotten the layout DDS04 E01
See page 13 of the user manual. screenshot 2024-04-14 at 10.54.12-undefined-undefined-0.png
4/14/2024 9:55:10 AM • Washing Machines • Answered on Apr 14, 2024
2answers
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error. Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract. If the fan is working then it's probably an inverter.
4/10/2024 5:59:51 PM • Washing Machines • Answered on Apr 10, 2024
Hayward 250 HD. Control panel does not display the temperature.
I am sure I answered this yesterday? You posted to washing machines category and this appears to be a gas fueled pool heater. You would be best contacting a service engineer because it is gas powered, although if it does blow up, it is outside or will only blow up the pool house.
Universal H-Series Natural Gas 250000 BTU Low NOx
Hayward Pool Products https://hayward.com > universal-h-series-natural-gas-250... Universal H-Series Natural Gas 250,000 BTU Low NOx. Hayward. SKU: W3H250FDN. Service and diagnostics manuals https://www.google.com/search?q=hayward+250+hd+service+manual ..
4/9/2024 5:23:09 AM • Washing Machines • Answered on Apr 09, 2024
2answers
Installing transit bolts
advise you take the top off so you can see where the bolts locate
4/7/2024 9:51:13 PM • Washing Machines • Answered on Apr 07, 2024
IG IGNIS 105 LA washing machine does not show and light after a low voltage run and power surge. please guide where to look into. I am located at a remote area in Nigeria.
If your IG Ignis 105 LA washing machine does not show any lights after a low voltage run and power surge, check the power supply, main control board, and internal fuses for damage. Consider contacting IG Ignis customer support for remote troubleshooting guidance or arranging for a technician to inspect and repair the appliance.Hi Tracey and welcome to JA, sorry for the delayed response, flat out all day here,, The clicking sound you speak of, is it coming from the door latch/catch area of the cabinet,, Can you lean down for me, seta wash program and listen very closly and pin point the origin of the clicking sound,, It will either be near the door handle on the door, or behind the control panel ok, Cheers. f3zblyr-undefined-undefined-0.jpg
4/7/2024 1:25:54 PM • Washing Machines • Answered on Apr 07, 2024
Sharp washing machine model ess119
What's problem machine can't start washing and water incoming non stop?
4/6/2024 4:01:36 PM • Washing Machines • Answered on Apr 06, 2024
How to reset the samsung wa7584c1 + control panel
How to reset the samsung wa7584c1 + control panel my washing machine returns the 1E error and its not the pressure switch. when i bypass it works but wants to reset it. How do i operate the control panel to reset. please help 1.To reset the control panel of your Samsung WA7584C1 washing machine, you can follow these steps: 2.Unplug the washing machine from the power outlet. 3.Wait for a few minutes to ensure that any residual power is discharged from the machine. 4.Plug the washing machine back into the power outlet. 5.Press and hold the "Start/Pause" button for approximately 5 seconds. 6.Release the "Start/Pause" button once the control panel lights up or resets. Check if the error code (1E) has been cleared. If the above steps don't work, consult the user manual of your washing machine for specific instructions on how to reset the control panel or troubleshoot the 1E error code. If the issue persists, it may be necessary to contact Samsung customer support for further assistance or to schedule a service appointment.
4/4/2024 7:39:20 PM • Washing Machines • Answered on Apr 04, 2024
What does the coues of E4 error on Aftron top loading washing machine error code?
When the E4 error appears on your Aftron top-load washer, it usually means there's an issue with how the lid closes or locks. This error prevents the washer from knowing if the lid is shut tightly during use. * Ensure the lid is completely closed and latched. If it's not fully closed, the washer will not start. * Inspect the lid lock for any damage or blockages (e.g., dirt, debris, faulty latch) as these can prevent the lid from locking. * Power off the washing machine and unplug it briefly, reconnect the power and restart the machine, this reset may resolve the error. * Use a multimeter to check if the lid switch has continuity, this test will determine if the switch is functioning properly.
4/2/2024 4:40:28 PM • Washing Machines • Answered on Apr 02, 2024
How do I open my Teka washing machine? door is locked
using the flat head screw driver firmly push the tip to the correct direction of the catch and the door would open
4/2/2024 3:51:28 PM • Washing Machines • Answered on Apr 02, 2024
What does the error code EC on a Defy top loader mean?
Errors TE, EC, TC mean that the temperature sensor that measures the temperature of the water in the unit is not working properly. Some codes - for example, TE - appear only before the start of the wash. These codes are typical of both ordinary washers and those that have a drying function.
4/1/2024 8:28:24 AM • Washing Machines • Answered on Apr 01, 2024
EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer Combo with Adapter Kit - CWD1510WKIT Logo
2 questions posted
Top EdgeStar Washing Machines Experts
john h
Are you an EdgeStar Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • EdgeStar Washing Machines
Most Popular Question
e64 error code door remains locked
  • Washing Machines
