20 Most Recent
DEWALT D512381 18Gauge Brad Nailer ORing Service Kit Questions & Answers
I have a fairly new
Usually, a poping sound within the nailer is indication that the driver piston is stuck in place. The "pop" is air pressure entering the cylinder, however cant move the piston. Easy fix. Remove the head and pull out the cylinder and driver. If the driver stays stuck in the nose, loosen screws at nose and remove the driver. Most likely driver is bent (repair or replace as needed, driver sold in kit or seperately). Lube all internal parts with silicone paste lube. Most likely drivers to bend or get stuck is 18 and 22 gauge because they are so thin. Fifteen and sixteen gauge drivers last much longer but cost more. Order two drivers if you are driving nails into hardwood (good to have spare ready to go so you do not have to stop project). On very hard wood, may be good idea to drill a pilot hole part way in to prevent damage to driver. Good luck
Hey, I'm having trouble with my Dewalt 18ga
For removal of dewalt D51238k trigger valve. Remove the nails.
Remove the pin holding the trigger in place. Then remove two roll pins in the body of the gun just above the trigger (3mm roll pins). With gloved hand, apply air pressure to the gun which will pop out the trigger valve. Use caution because the valve could come out with force. Try with low pessure first, then increase as needed. If you are removing the trigger because the gun will not fire, (only puff of air from trigger area), suspect problem in the head valve instead (usually, trigger valve is bad if air leaks from trigger when you connect air ). Good luck
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/
An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder.
An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
