20 Most Recent Dewalt Planer (DW734) Questions & Answers
3answers
When a board goes thru the cutting bars raise up. we have checked out and tightened the locking bar. everything seems fine.
Educated guess that the adjustment screw (knob) is not locked OR the screw shaft is worn on the top/bottom allowing the gear to jump off the screw thread. Does it shake when the planner is off? A question is Is the thickness indicator still showing the original setting? From another site: Once the height is set, remember to push the black bar back down to lock the cutting head in place. DeWalt web site customer rep might be able to assist you.
9/26/2019 5:54:32 PM • Dewalt Planer... • Answered on Sep 26, 2019
2answers
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735. Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check. A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick. I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time? A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
5/14/2016 9:33:23 PM • Dewalt Planer... • Answered on May 14, 2016
About halfway thru a board, the pressure releases and the cutting bars raise up. we have tightened everything on the locking bar but it still does the same thing.
Duplicate question. See Q&A at: http://www.fixya.com/answer/answerpageslideview.aspx?thid=25656501
5/15/2015 2:57:41 AM • Dewalt Planer... • Answered on May 15, 2015
The planer trips its circuit breaker after only planing for two or three minutes
Check out the circuit breaker - they get old and trip too easily.
7/29/2014 1:32:14 AM • Dewalt Planer... • Answered on Jul 29, 2014
Dw734 planer
More than likely the screw threads are gummed up. Make sure the locking mechanism is up and lower the carriage. Clean the screw threads, spray with WD40 and wipe off the excess. I had the same problem because rarely raised the carriage above 2". Hope this helps!
7/7/2014 2:41:26 AM • Dewalt Planer... • Answered on Jul 07, 2014
Change the belt on a dewalt 733 planer
Here is a link to a site I am a member of, Lumberjocks.com. The link is for a discussion on how to replaced the belt on your planer! Good Luck! http://lumberjocks.com/topics/10176
7/7/2014 1:45:02 AM • Dewalt Planer... • Answered on Jul 07, 2014
Chain feed skips
chuck or worn chain cog
4/8/2014 4:34:57 PM • Dewalt Planer... • Answered on Apr 08, 2014
My planner won't draw the wood thru my planner.
check that blade is correct and guides correct
4/8/2014 4:32:01 PM • Dewalt Planer... • Answered on Apr 08, 2014
2answers
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
3/16/2014 9:34:49 AM • Dewalt Planer... • Answered on Mar 16, 2014
Thickness planner will not lower the head evenly
WD40. On all moving parts and surfaces that touch each other.
11/22/2013 12:52:27 AM • Dewalt Planer... • Answered on Nov 22, 2013
The planer keeps tripping its own circuit breaker.
There is a wire that is shorting out some where on it.. I would start with the switch then go to the cord.. If that doesn't work, you'll need to take it a part and look for a striped or broken wire. I’m happy to assist further over the phone at https://www.6ya.com/expert/jay_17408fb1a2cad107
10/29/2013 6:09:06 AM • Dewalt Planer... • Answered on Oct 29, 2013
The self-feed slips on my Dw 734 Planer.
I have had the same problem with my planer since it was new. I hate this planer. The way I fixed it was to pull the feed rollers off and put one washer in the hole the pressure springs are on the rollers. I also put about a 1/32 washer under the hold down plate for the roller. It allows the rollers to put more pressure on the wood. Now it works perfect. If it sounds complicated, it will all come together when you take it apart. You take the bottom off to do all this. Trust me it works and is worth the trouble to do it.
8/7/2013 3:28:47 AM • Dewalt Planer... • Answered on Aug 07, 2013
Carrage won't hold thickness
Either it is not really locked in place, you have a loose nut on the other end of the adjuster or a bad bearing.
9/26/2012 4:55:21 AM • Dewalt Planer... • Answered on Sep 26, 2012
Need owners manual for Delta DW734 thickness
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
11/18/2010 8:01:34 PM • Dewalt Planer... • Answered on Nov 18, 2010
How to change Blades on Dewalt DW 733 Planer
Go to Dewaltservicenet.com and in the middle of the page towards the bottom is a box indicating manuals/breakdowns. Type in your model number and you can download one this way.
7/21/2010 11:56:59 PM • Dewalt Planer... • Answered on Jul 21, 2010
How do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
7/17/2010 2:38:55 PM • Dewalt Planer... • Answered on Jul 17, 2010
I want to make a necklace for my sons wedding with pearls but they are so small and delicate I am not sure what thread will work with it?
Pearls often have very small holes. You need to use a natural silk thread or another very fine thread. It really depends if you plan to knot between pearls, if so that will affect your choice of thread, so make sure you get advice from a beading expert before you buy.
4/7/2024 2:22:50 AM • Crafts & Hobbies • Answered on Apr 07, 2024
Are there soap making kits that are good for kids?
Amazon have a good soap making kit for kids but if your kids are young you should make sure that you supervise the hot parts as it can be quite dangerous.
http://www.amazon.com/Cool-Kids-Soap-Kit/dp/B00124WCJ0
3/18/2024 9:18:03 AM • Crafts & Hobbies • Answered on Mar 18, 2024
2answers
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem. To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue. cricut explore air 2-ibihixnmadozsxrjeznrdibm-d-1.png
3/11/2024 12:35:42 PM • Crafts & Hobbies • Answered on Mar 11, 2024
Dewalt Planer (DW734) Logo
28 questions posted
Top Dewalt Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Crafts & Hobbies
Most Popular Question
dewalt 735 planer turn blew house fuse
  • Crafts & Hobbies
