20 Most Recent
Binks Hvlp Spray Gravity Gun With 1 Liter Cup Model SV100 Questions & Answers
In trying to spray oil
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Binks model 35 spray gun manual
Man ur needle is worn or bad altogether...look on the back of the fluid needle, might be adjustable...if so, roll the nut FORWARD about a whole turn. If not adjustable...
My binks model 18 spray gun sprays inconsintaly on off on off ect.
this can be contributed to the seals around the needle part of the trigger operation
they get hard and don't seal properly
check gland seal nut for adjustment to place tension on the gland to make it seal
make sure that air bleed hole in the lid is clear and not blocking off
