20 Most Recent Stanley Bostitch Rn461 Gun Coil Roofing Nailer Questions & Answers
tip
The Best Benefits of Metal Roof Coatings By Conklin
When our white roof coatings are applied to commercial metal roofs you will save money since the frequent local roof repairs will be virtually eliminated. When roof damage occurs from wind and hail storms occur elastomeric white roof coatings are the default choice. In reality Conklin Roofing Systems should be your default choice since they manufacture the best products in the market. http://roofinghorizon.com/conklin-elastomeric-roof-coatings-austin.html
2answers
I have a Bostitch RN46 roofing nailer that has
SOUNDS LIKE YOU MAY HAVE RIPED THE DIAFRAM THAT CONTOL THE PLUNGER MOST OF THE TIME I REMOVE IT IF BAD I REPLACE IT
7/27/2016 8:56:34 AM • Stanley Bostitch... • Answered on Jul 27, 2016
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
10/18/2015 11:03:41 PM • Stanley Bostitch... • Answered on Oct 18, 2015
2answers
I have a bostitch rn46 nail gun. Does the diafram
This link will show you a picture of all the parts that come in the kit:
http://www.bostitch.com/default.asp?CATEGORY=BOS_PERF_REBUILD_KITS&TYPE=PRODUCT&PARTNUMBER=RN46-RK&SDesc=Rebuild+Kit
Parts can also be ordered individual:
www.toolpartsdirect.com
2/8/2015 10:37:47 PM • Stanley Bostitch... • Answered on Feb 08, 2015
Air leaks through cap vent
I had the exact same problem after doing a complete rebuild. If you are using the Stanley bostitch rebuild kit, check to see if you accidently swapped o-rings 6 and 63. They look the same but o-ring #6 is 1.925x.103 and o-ring #63 is 1.862x.103. Use plenty of lubricant. Hope this helps.
12/30/2014 2:07:44 PM • Stanley Bostitch... • Answered on Dec 30, 2014
2answers
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
10/25/2014 3:38:59 PM • Stanley Bostitch... • Answered on Oct 25, 2014
2answers
How can I stop a RN46-1 from jamming
We often see jamming with stainless wire collation - the problem is almost never the gun, it is because the stainless wire is much harder to shear off than regular steel. I would suggest trying another brand of nail and see if that helps. Also, yes, the trigger is all that is required to change it to sequential, it is a very easy swap.
10/21/2014 6:29:30 PM • Stanley Bostitch... • Answered on Oct 21, 2014
0answers
0answers
Ne to conver roofing nailer back to sequential fire
You need Bostitch part 105782 Sequential trigger assy. One roll pin holds it in place, its an easy change
6/11/2014 1:42:38 PM • Stanley Bostitch... • Answered on Jun 11, 2014
How to remove a broken nail head from the driver pin
It depends on how it is jammed - most of the time you need a long drive punch the diameter of the driver and carefully hammer the driver past it. The roofing nailers aren't as hard to free as the framing guns so you should not have any trouble.
6/10/2014 11:36:22 PM • Stanley Bostitch... • Answered on Jun 10, 2014
2answers
Driver not retracting
need to rebuild, or check the head ( grease orings with lithium grease sometimes dry)
6/10/2014 11:25:27 PM • Stanley Bostitch... • Answered on Jun 10, 2014
Trigger is leaking air and trigger is not working
replace trigger valve assembly aka tva 6 you can get aftermarket ones fairly cheap that are just as good. it is fairly easy to do, usually takes about 10-15 min, lots of how to on you tube look under bostitch rn46 trigger
5/26/2014 9:16:05 PM • Stanley Bostitch... • Answered on May 26, 2014
How to get the retaining ring off of the feeder assembly
The rn46 nailer has two retaining rings for the feeder. The snap ring on the very back of the feeder assembly is removed with snap ring pliers or two small pointed tools of your choice. The rear cap will come off with spring pressure so be ready to catch the pieces. You need to remove the nail canister to see the rear snap ring. The feeder pin holding the feeder onto the feeder shaft is just a rubber ring that can be removed by prying behind with flat blade screwdriver. Caution when you remove the feed-pin and move the feeder or you will lose the feed-sping under the feeder , Good luck
12/7/2013 5:51:13 PM • Stanley Bostitch... • Answered on Dec 07, 2013
My brand new bostich roofing gun froze up after
Water in gun or wrong oil for cold temp will cause gun to freeze. Make sure that the compressor is not making water form in hoses due to hot air entering cold hose then freezing in gun. Remove cap of nailer and check for water and lube with light oil that remains liquid in your temp range. If the oil is too thick, the firing valve under trigger and headvalve will not budge. Use very short hose so warm air in tank can reach the nailer (heat is produced when air is compressed, however long hose will allow air to cool before entering gun). Stay warm and good holidays
12/2/2013 10:29:35 PM • Stanley Bostitch... • Answered on Dec 02, 2013
Shoots every other nail
Check the feeder area located just before the plunger. This sometimes can bind because of a lack of oil. If that appears OK, then I'd dis-assemble the unit and clean it completely. Use the diagrams at the site below to assist. Enter the model number on the first page to get to the diagrams for your unit.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CLyNls3l0KMCFeoD5QodWw4_wA
10/30/2013 5:45:55 PM • Stanley Bostitch... • Answered on Oct 30, 2013
New nailer has low air pressure
Assuming that you mean low power becauss pressure is adjusted at the compressor and should be set to between 90 to 100psi. Pressure at the gun should not drop below say 80 psi. Low power is generally caused by worn piston oring. Easy test, open side door and remove the nails. If the driver drops to bottom and moves when you tilt the nose of the gun up, piston oring is worn. Replace with part # 850607 or universal oring number #222 available at bearing retailer. Good luck with your nailing projects.
10/29/2013 3:49:48 PM • Stanley Bostitch... • Answered on Oct 29, 2013
Stanley Bostitch Rn461 Gun Coil Roofing Nailer Logo
38 questions posted
Top Stanley Air Tools & Compressors Experts
john h
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Air Tools & Compressors
Most Popular Question
stop rn46 1 from jamming
  • Air Tools & Compressors
