20 Most Recent
Yamaha RX-595 Receiver Questions & Answers
Does not switch on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .if it stays on whit no wires attached than u have short connection at speaker wires . if doesn`t come on then try to fasten screws at back of the unit , may sound like BS but if amp board don`t have good ground connection it can go in protection mode
Yamaha RX-595 right channel is
Since all the inputs, except the radio, are working, the problem is not at the main part of the amplifier. The most suspicious point for this kind of problem is the input function switch. Move it many times from any input to radio and back in order to "self-clean" the contacts. Take a look also at the balance knob; it has to be at the center position. Also check the results for various radio stations.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Yamaha Receiver
yes.. Sorry i will go to my uncles and write it down for you... Then post it over the next couple of days.. Cheers
Right speaker goes off when using Rec out on the Phono input
The switch is contaminated. Pick up some electronic switch cleaner and spray into the switch. Move the switch back and forth a number of times and that should clear up the problem. Make sure that you get the cleaner that has a lubricant included.
Dan
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
