20 Most Recent Yamaha RX-V540 Receiver Questions & Answers
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
1/28/2022 5:50:39 AM • Yamaha RX-V540... • Answered on Jan 28, 2022
How do I reset to factory default?
How do I reset an RXV 5:40 to factory reset I pushed on button it turns on but turns right off
9/23/2018 6:02:06 AM • Yamaha RX-V540... • Answered on Sep 23, 2018
Help... LOL
it could be a screen cable fault. there is not much info on this model but would believe it would be the 2 cables on the lcd. if its the old tube type tv, when its been transported something could of come loose inside cable or a soldered part, to you would have a dry joint hope this helps
5/14/2017 6:10:51 AM • Yamaha RX-V540... • Answered on May 14, 2017
0answers
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
1/21/2013 2:12:32 PM • Yamaha RX-V540... • Answered on Jan 21, 2013
Yamaha RX-V540. I have had
If it's still sufficiently loud, why bother replacing it? Our hearing is subjective. Do all sources exhibit a lower level than you remember? If not, what's unique about the audio signal path for 'movies'.
2/5/2011 2:46:11 PM • Yamaha RX-V540... • Answered on Feb 05, 2011
The unit keeps turning off
Let's just treat this as self-protection:
Make sure all speaker connections are tight.
Make sure the Impedance Selector switch it set fully in one of its two positions.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
1/28/2011 11:43:05 AM • Yamaha RX-V540... • Answered on Jan 28, 2011
Control remote not working, i
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! If that doesn
1/22/2011 11:12:04 PM • Yamaha RX-V540... • Answered on Jan 22, 2011
Why does my Yamaha HTR-6130 power down after 3 seconds?
I expect there is either a power supply issue or one of the amplifiers has failed causing over current to turn it off as a protection to the power supply.
4/20/2024 6:23:32 AM • Yamaha Audio... • Answered on Apr 20, 2024
Can I connect my computer subwoofer to my Yamaha A/V receiver
Yes if it has a suitable speaker connection available and is nominally 8 ohms impedance Speaker and AV.
4/15/2024 11:25:42 PM • Yamaha Audio... • Answered on Apr 15, 2024
Yamaha M-60 Power Amplifier distortion and sound goes off sometimes
Being from 1985 or there abouts, it probably needs some TLC at a Yamaha service centre. May need new capacitors and resolder dry joints for age related issues.
4/1/2024 7:26:20 AM • Yamaha Audio... • Answered on Apr 01, 2024
Jerky sound in one channel Yamaha M-60 Power Amplifier
WD-40 ... Very dangerous as it not only flammable when wet but is bad for electrical contacts as it leaves a residue behind that does not conduct electricity very well. Check speaker connections first.
4/1/2024 7:22:45 AM • Yamaha Audio... • Answered on Apr 01, 2024
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool. the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny). ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
3/5/2024 10:05:15 PM • Yamaha Audio... • Answered on Mar 05, 2024
RX-V6A - Zone 2 Speakers do not give sound
Follow the procedure as given in following link. RX-V6A ' ENJOYING IN MULTIPLE ROOMS (ZONES) (yamaha.com)
12/14/2023 12:29:06 PM • Yamaha Audio... • Answered on Dec 14, 2023
Yamaha YST-FSW050 Ultra-compact powered subwoofer. It has bad vibration between 30-50 hz?
Question edited for clarity, full make model (what it is)'. Question moved to Yamaha Audio. It may be sympathetic vibration and is coming from something nearby. Put it on a folded towel or sit in the floor to test it. https://www.google.com/search?q=YST-FSW050+bad+vibration ..
12/9/2023 7:36:22 PM • Yamaha Audio... • Answered on Dec 09, 2023
Yamaha RX-V540 Receiver Logo
12 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
control remote not working
  • Audio Players & Recorders
