20 Most Recent Digimate DGL26 Television Questions & Answers
0answers
4answers
Digimate Remote Control?
6/18/2013 3:28:24 PM • Digimate DGL26... • Answered on Jun 18, 2013
2answers
I AM UNABLE TO FIND THE REMOTE CONTROL CODE FOR PROGRAMMING DIGIM
This is a very common problem often without a solution. I'd recommend you check your signal provider's website since they will have an updated code chart but there may never be a code for your brand available in their or every other remote. Also, some store or off- brands are not widely enough sold to encourage remote providers to worry about them.
12/8/2012 3:32:00 AM • Digimate DGL26... • Answered on Dec 08, 2012
The tv won't turn on
how to fix
8/13/2012 11:55:53 PM • Digimate DGL26... • Answered on Aug 13, 2012
No picture
If you TV is a LCD one, it seems to me that this problem is related with the inverter circuitry which supplies high voltage to the LCD. The presense of sound means that the main power supply is OK. To repair this fault you must look for help of someone qualified to do this particular repair. I hope my aswer will be of help for you.
6/2/2012 7:56:55 PM • Digimate DGL26... • Answered on Jun 02, 2012
Where can i get ac
Which cord?
6/13/2011 9:32:40 PM • Digimate DGL26... • Answered on Jun 13, 2011
2answers
Wher to get the powere supply (FSP180-3M02) for DGL26?
If you can locate an FCC number on the model/serial number tag, you may be able to find who actually built the set; their company name is likely different than the brand name.
If you are lucky and the number is present (ever more often NOT), go to the FCC search page:
Research FCC number
1/7/2011 4:54:28 PM • Digimate DGL26... • Answered on Jan 07, 2011
What other cables nbesides the dvi cable do i need
An AUDIO cable to the TV PC AUDIO INPUT PORT (see Green mini phone jack on the back of the TV for PC AUDIO) another end of the mini stereo phone plug will go into the PC AUDIO LINE OUT (Green miniphone jack).
11/7/2010 4:14:25 AM • Digimate DGL26... • Answered on Nov 07, 2010
I want to be able to use my Digimate with antena only
Go into your set's setup menu and make sure it is set to "Antenna" rather than something else. Any flat panel TV less than ~ 3 years old will be compatible with 'over-the-air' HD broadcasts.
5/25/2010 6:41:11 PM • Digimate DGL26... • Answered on May 25, 2010
Power supply for digimate dgl26
In seems like this brand of TVs do not have service parts or they are not longer being manufactured.
I repair these power supplies. If you need further assistance, write to [email protected]
6/7/2009 3:59:55 AM • Digimate DGL26... • Answered on Jun 07, 2009
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to [email protected]
1/13/2009 5:06:03 PM • Digimate DGL26... • Answered on Jan 13, 2009
2answers
27 inch Digimate LCD TV Shuts Off Automatically
have you had this probelm fixed mine just starteed to do it and its only 8 months old and I cant afford to have it fixed please help if you can thanks
11/28/2008 3:28:44 PM • Digimate DGL26... • Answered on Nov 28, 2008
Audio cuts in and out. Can restore by shutting off tv or cycling the mute.
yeah, i have the same problem, no anser, just a note to say i have the same problem
11/22/2008 5:46:58 AM • Digimate DGL26... • Answered on Nov 22, 2008
Lines while watching TV
Lines = bad circuitry. Could be a microchip. Could be a bad power supply to the microchip. Only a tech could look and tell.
11/14/2008 9:41:54 AM • Digimate DGL26... • Answered on Nov 14, 2008
DIGIMATE DGL26
Yes ofcourse. Just check the specs marked on them.. You can get them at any local electric store..
7/23/2008 4:17:00 AM • Digimate DGL26... • Answered on Jul 23, 2008
Cant see any tv?
look at your surrounding maybe you can see tv .
2/20/2008 8:50:27 PM • Digimate DGL26... • Answered on Feb 20, 2008
Digimate DGL26 Television Logo
30 questions posted
Top Digimate Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Digimate Televison & Video
Most Popular Question
no picture
  • Televison & Video
