20 Most Recent
Grindmaster Pourover Brewer - 18 Questions & Answers
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
I have a Grindmaster model 805 coffee grinder. It
Most grinders, especially the larger professional models will eventually need to have the grinding wheels (set of 2) changed out. They do wear down. The grinder will struggle as the burrs on the wheel dull out. This increases the time it takes to grind coffee and puts a heavy electrical load. Burnt out switches, tripping breaker, overheating, and burnt coffee grounds on espresso size are all symptoms of a worn burr set.
It's common to find; stones, nails, jewelry, and small loose things found around coffee counters in the grinding wheels or burrs. Have a qualified operator remove all beans and hopper to check and brush out burr set. This should be done every day. Talk to your vendor if you find nails as they can easily correct this with a magnetic pick up.
Another cause is very oily beans. Sometimes poorly roasted beans come out extremely oily which will gum up everything from the burrs, Moving parts, and electrical components. Disassembly of entire machines may be necessary.
.Final note; since you mentioned a switch swap. It's possible the switch is underrated for use in this machine. Most will work in a pinch but like a 'spare' tire in a car, they are only ment to get you to a service center for replacement.
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
