20 Most Recent
C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic Questions & Answers
Drains battery
my aftermarket alarm used to drain my battery. fixed it by removing alarm system.
My remote says no antenna. can not arm alarm.
REPROGRAM YOUR REMOTES USING THIS PROCEDURE:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
All of the sudden my light quit flashing and horn
The alarms is in valet mode. Find the toggle or push button switch. Put the ignition key to the on position and then move or keep pressed the toggle/push button switch until you hear a beep. turn the key to the off position and try it.
Lights dont flash when arming and disarming system
If the lights on your system are not flashing when arming and disarming, there could be a few reasons for this issue. Here are some potential causes and solutions:
- System Configuration:
- Check https://mmfinancials.pk/gold-prices-in-pakistan-experience-a-dip-in-line-with-global-trends/ the system configuration settings. Some security systems allow users to customize the behavior of lights during arming and disarming. Ensure that the settings are configured to activate the lights as desired.
- Power Supply:
- Verify that the system has a stable power supply. If the power is insufficient or there's an issue with the power source, it may affect the functionality of the lights. Check for any loose connections or power interruptions.
- Light Bulbs:
- Inspect the light bulbs associated with the arming and disarming indicators. If the bulbs are burnt out or faulty, they may need replacement. It's a simple fix, but it can have a significant impact on the visibility of the system's status.
- Sensor Issues:
- Some systems use sensors to detect arming and disarming actions. If these sensors are malfunctioning, they may not trigger the lights properly. Ensure that the sensors are clean, properly aligned, and functioning correctly.
- System Software Update:
- Check if there are any software updates available for your security system. Sometimes, manufacturers release updates to address bugs or improve functionality. Updating the system software may resolve the issue.
- Faulty Wiring:
- Examine the wiring connecting the lights to the security system. Loose or damaged wiring can disrupt the communication between the system and the lights. If you find any issues
My auto page alarm wont
I have 09 envoy 4x4 with auto page remote with electric start but it stopped unlocking my doors ? It worked and now nothing just locks and start work any fix to this issue ?
Xt 65 h50t31
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
How to program a autopage alarm remote control
Try it out brother
Autopage c3-rs car starter wont work
Try it out brother
Where is the sim number on a autopage alarm
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few like reliable-store... let me know if u need help
thanks
My autopage xt-43lcd needs reprogrammed
why don't u try online websites..
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
let me know if u need help I know plenty
WIRING DIAGRAM FOR AUTOPAGE RS-615
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
