20 Most Recent
Pit Comp 3 Old School Bmx Bike Tire 16" X 175" White Questions & Answers
Hi my 125 starts but cuts out
the carb float level is probly off--u need a repair manual for that model or ask the manufactur the measurement------may also b gittn a weak spark-----library has a motor section in ur city
3/31/2014 8:49:56 PM •
Pit Cycling
Answered
on Mar 31, 2014
Do you need a back brake on a 110cc pitbike
It'll run without one, but I don't advise it. It adds more braking power and the rear brake is needed in certain situations where using the front brake can be more dangerous, such as slick surfaces. The rear brake can also be used to get the front back down in the event of an unwanted or out of control wheelie.
1/31/2014 3:47:19 PM •
Pit Cycling
Answered
on Jan 31, 2014
My 125cc sputters and jumps
what make is your bike.I have a jinlun 125 that starts ok but loses power sounded electrical to me could be wrong.
2/27/2013 12:27:56 AM •
Pit Cycling
Answered
on Feb 27, 2013
Valve gap clearance for 200cc
just go to the repair shop and change the tube along with the tire or whole wheel of your cycle as per your requir...
since you have not mention detail of your problem and i not uploaded the picture of your bicycle i cant help you more than this.
sorry dear friend!!!
this happens due to lack in quiry,..
best of luck!
regards!
7/20/2011 8:40:46 AM •
Pit Cycling
Answered
on Jul 20, 2011
Hi i have a 120
Got the same problem ile post bk as soon as I find out what it is.
6/3/2011 10:07:37 AM •
Pit Cycling
Answered
on Jun 03, 2011
Hi my pitbike isnt running
try a new spark plug first.if no different look at your carb dependining on what model you have you will see on the side ethier 1 or 2 screws usualy 1 as a spring the othe doesnt hold you throtal full on in neutral after warming it and with a screw diver turn the screw whithout the spring qaurter turns but count as you know ware it was first you will here the difference in the engine
4/4/2011 10:28:33 PM •
Pit Cycling
Answered
on Apr 04, 2011
There is no spark it
there are 2 things you can do
1. check the plug/coil connection
2. make all the coil wires are hooked up properly
3. buy a new coil
3/24/2011 4:44:55 PM •
Pit Cycling
Answered
on Mar 24, 2011
When i pull the excellerater
you could check 1 of 3 things
1. the type of gas/ mixture
2. check the oil ( regular oil changes )
3. exhaust leak from the head
3/24/2011 2:23:09 AM •
Pit Cycling
Answered
on Mar 24, 2011
