20 Most Recent Cannondale Lefty Alloy Dlr Mountain Bike Fork Shock 110 Questions & Answers
How do I fix an oil leak on my cannondale lefty
First try to replace the oil and replace the oil seals then inspect the tubes for scratching/gouging while you have them apart.
9/27/2014 11:22:54 PM • Cannondale Lefty... • Answered on Sep 27, 2014
2answers
Where are the adstments on
Cannondale.com
4/30/2014 11:11:45 AM • Cannondale Lefty... • Answered on Apr 30, 2014
Shipping a bike. dismantling instructions;
Since there are a lot of varieties of the Lefty go here and search the list for "LEFTY".
http://www.cannondale.com/manuals
Or you might just get away with deflating the pressure preload and collapsing the fork.
7/2/2011 7:29:17 PM • Cannondale Lefty... • Answered on Jul 02, 2011
I just bought a used
Hello ledpencil,
Pneumatic bike shocks require a special type of pump called a "shock pump" that is a high-pressure (up to 300psi!) but low-volume pump. They come with a very accurate gauge, pump handle, and a bleed valve/button to let off puffs of air to soften the shock. They also have a long flexible neck that screws onto the valve at the base of the fork. They're relatively small and moderately priced ($20-$40) and can be packed in a riding pack in case you want to change the stiffness on the fly. Here's a link to some online: http://www.jensonusa.com/store/sub/292-Pumps+And+Co2+Inflation-Shock+Pumps.aspx?s=1559&mfg=0&closeoutHotdeal=&use=&sort=Default&show=25&pricemin=0&pricemax=100
Hope this helps! -The Chicken
4/5/2011 4:52:46 AM • Cannondale Lefty... • Answered on Apr 05, 2011
How to dismantle cannondale lefty
http://www.cannondale.com/usa/usaeng/Instructions
select Lefty in the right side rolldown
Lots of manuals
2/27/2011 4:56:07 PM • Cannondale Lefty... • Answered on Feb 27, 2011
How can I date a Cannondale bike? the serial number is QM21730
Google "cannondale serial number". That is what anyone else would have to do to answer your question.
6/12/2019 1:42:58 PM • Cannondale... • Answered on Jun 12, 2019
What size thread are the pedals on a cannondale quick bike
They are a standard thread - 9/16 x 20. ANY standard bicycle pedal will fit. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
5/22/2017 11:04:21 AM • Cannondale... • Answered on May 22, 2017
What year cannondale with srrial numbericc012b04624
Search for the make and model at BikePedia, then look for the paint scheme of your bike. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
3/27/2016 3:14:19 AM • Cannondale... • Answered on Mar 27, 2016
Find year from serial number en14764
Usually not possible to ID bike from serial# alone. Unless it's been repainted and decals removed the best way to tell is to search for the make and model at BikePedia You can then generally figure out the year from the paint scheme and equipment. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
3/27/2016 3:10:43 AM • Cannondale... • Answered on Mar 27, 2016
2answers
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
3/23/2016 1:03:55 PM • Cannondale... • Answered on Mar 23, 2016
Where can I check my bike serial number for information
Hello Trey, If it's recent, the serial number is on the frame under the crankshaft, if it's older it may be other places. . . look here for older ones:http://vintagecannondale.com/info/. Thanks!
2/9/2016 5:50:29 PM • Cannondale... • Answered on Feb 09, 2016
Wt year is this F120123039
Contact your local Cannondale dealer for assitance
11/24/2014 5:25:21 AM • Cannondale... • Answered on Nov 24, 2014
0answers
Error 202 canon
Be the first to answer 8/11/2014 9:15:02 AM • Cannondale... • Posted on Aug 11, 2014Be the first to answer
Cannondale swingarm replacement
Only Moto1 swingarms fit on them. Swingarms are specific to models.
2/2/2014 4:01:38 AM • Cannondale... • Answered on Feb 02, 2014
Cannondale Lefty Alloy Dlr Mountain Bike Fork Shock 110 Logo
10 questions posted
Top Cannondale Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
View Most Popular
Cannondale Cycling
  • Cannondale Cycling
Most Popular Question
just bought used
  • Cycling
