20 Most Recent
K2 Stormy 20" Girls' FrontSuspension Mountain Bike Questions & Answers
Freewheel fails
I assume you means that it slips sometimes. This is usually due to the ratchet mechanism just needing a bit of lube. If you have a thread-on type freewheel (see image below) then you can usually just squirt some WD40 into the little holes near the center of the freewheel. Those holes would be facing the table in the threaded freewheel pictured below. If that doesn't work for you, it's not all that difficult or expensive to just replace the whole freewheel. However, if you have the splined type pictured on the right, the ratchet mechanism is in the wheel's hub, making replacement more of a big deal. WD-40 would probably do the trick on this type too, but I never had one some I'm not certain how easy it is to get the lube where you need it. Good luck!
11/8/2012 3:15:12 PM •
K2 Cycling
Answered
on Nov 08, 2012
Raise handlebars
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
9/3/2011 3:49:36 PM •
K2 Cycling
Answered
on Sep 03, 2011
My daughter undid the quick
The cable runs through a bent piece of aluminum tubing called a noodle. At the end of the noodle is a piece that looks like the business end of a bullet. You need to squeeze the two brake pad levers and insert the bullet on top of the cable catch.
8/19/2010 6:22:04 PM •
K2 Cycling
Answered
on Aug 19, 2010
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
A manual for a manual for a Genesis model gs52686 men's bike a V2 100
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
3/14/2023 6:23:13 AM •
Cycling
Answered
on Mar 14, 2023
