20 Most Recent Nostalgia Electrics Classic Music Jukebox Retro Nostalgia AM/FM Radio CD Player Shelf System Questions & Answers
The problem is probably in the keyboard. Clean all the contact switches you can get to with very fine sandpaper. The reason it is stuck is it is waiting for that third selection to complete the circuit.
Nostalgia... | Answered on Apr 16, 2016
I have a model 464 and my problem was similar but mine was the second digit.
I replaced the p c board in the selection control box and my problem was gone.
I would check the selection control box.
Hope this helps
Nostalgia... | Answered on Jan 17, 2013
error code 30 =memory contents invalid you need to reprogramme
Nostalgia... | Answered on Sep 08, 2011
I am not sure it is much help but as far as I know the eprom is in the computer. The computer is directly below the CD player.
So duff computer?
Nostalgia... | Answered on Apr 13, 2011
I HAVE THE MANUAL AND SERVICE PROGRAMME ON A DVD DISC EMAIL ME I WILL SEND IT PHILHEMMINGS@HOTMAIL.COM
Nostalgia... | Answered on Dec 12, 2010
error 73 means error during grip from magazine check for lift jamming,check function and adjust,i had one recently the same fault found it easy to replace the cd changer complete for 65.i do have the manual and service guide if you need one just email me
Nostalgia... | Answered on Sep 17, 2010
No, but like any machine, it does need lubrication once in a while. You should purchase a manual for it (eBay).
If the clutch has become stuck, it's time to call in a pro.
Are you sure it's in "PLAY" mode? Check to be sure the service switch is in "PLAY."
Does the motor turn?
If yes, try pressing the reject button on the back. Maybe it's stuck thinking it's playing a record in an empty slot (clamp arm will be against the turntable). There is also a manual trip lever just to the right of the tonearm. lift up on it if the motor is turning and see if that triggers it. Go ahead, it won't hurt you.
if the motor itself has frozen up from lack of oil, try putting some light machine oil (NOT 3-in-1 or anything paraffin based) in the oil cups on the side of the motor and letting it sit for a few hours. Then, turn the motor shaft by hand a little. This may free it up. if so, count your blessings and call someone in to give the whole mechanism a proper lubrication or something else will eventually seize up or wear out.
Good luck.
Nostalgia... | Answered on Feb 28, 2010
I do not know where to get the lamps however here is the information re the maker.
Helman Group WCD4090 CD Shelf System
www.helmangroup.com
www.hktdc.com
I hope this helps.
Regards
Alan Hood
ami-man
UK
Nostalgia... | Answered on Sep 08, 2009
If you are in the USA you can order a manual from a list of dealers that can be found on www.roweinternational.com or from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
THIS IS A COMMON PROBLEM. THE ONLY SOLUTION IS TO REPLACE THAT DOME.
GLUING WILL NOT WORK. APOXY WILL NOT WORK. THERE IS A LOT OF PRESSURE
AT THAT PLACE.
REPLACE THAT DOME IS THE WAY TO GO. GET N FRIENDS TO HELP, OR YOU WILL BREAK THE NEW DOME.
E-MAIL===SEYLEVITT@JUNO.COM
MAME IS SEYMOUR LEVITT
COMPANY NAME IN-HOME JUKEBOX REPAIR
6362273300
746 HENRY AVE BALLWIN MO.
Nostalgia... | Answered on Jun 16, 2009
release the orange case from the back and slide forewards.Note,use athin knife blade to ease the case sides 2no. from holding points on head.BUT THERE MUST BE A BETTER WAY???.
Nostalgia... | Answered on Nov 26, 2009
Just google it. We live in the 21st century, not to ask questions like this.
Audio Players &... | Answered 34 minutes ago
Nostalgia Electrics Classic Music Jukebox Retro Nostalgia AM/FM Radio CD Player Shelf System Logo
20 questions posted
Top Nostalgia Electrics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Nostalgia Electrics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Audio Players & Recorders
Most Popular Question
third select button will not stop down
  • Audio Players & Recorders
