20 Most Recent
SuperMicro X6DAL-TG Motherboard Questions & Answers
PCI Express slot, eight beeps
Yeah, but it's not the slot; it's the northbridge chipset or a PCI bridge driving it that's perhaps overheated or set funny. If you use 2 CPUs they can fall out of step several ways, or your clock circuits can age badly by themselves! Got fresh CMOS batteries in there? It could be that PCIe was merely asked to run at a frequency it won't run. You should carefully make sure the board is nice and clean, reflash or at least clear settings on the BIOS, confirm the PCI videocard boots, make sure all the chips are cooled well, and again see if you can get a PCIe card to work without complaint.
Supermicro x9sra Boot up
file:///C:/Users/Wajiha/Downloads/MNL-1281.pdf
http://kernelpanik.net/boot-selection-menu-on-supermicro-x9sra/
Intel d915GLVG mother board vrm is short and fun dose not work
An electrolytic capacitor has failed.
If one has failed it indicates that the board has overheated, and many other components are also weak.
This Intel board is not of good quality.
Replace with SuperMicro or Tyan, and improve the cooling airflow in the case.
H8dce no audio
Usual cause.
Under the Chip Set Menu in the BIOS
Under South Bridge Configuration
The setting Audio CODEC Interface has been set to disable.
Linux drivers serial
The first place is always the Debian Linux website, because most Linux packages are derived from Debian.
Post code 38
"The BIOS can not shadow the ROM into system memory."
This is usually caused by the ROM on a card trying to use the same memory space.
Remember all of the ROMs have only the memory addresses from C800 to FFFF in the first megabyte available for shadow.
This was designed in in the first IBM PC and remains to this day.
Remove the other cards, and turn off both system ROM shadow, and video ROM shadow.
PDSMI
If you are good with a soldering iron the capacitors can be replaced.
Make sure you can wick the excess solder out of the holes.
Replace only with Japanese capacitors, and increase the airflow in the case and around the capacitor.
This is usually a sign of overheating.
